crypto ipsec security-association multi-sn
hi,
is it possible to configure
per peer? I am trying to resolve anti-reply errors and this command needs to be configured on both side of ipsec tunnel. One router involved has many tunnels and I need to configure this only on one.
br
14 Replies 14
M02@rt37
Hello @DraganSkundric87318
No, it's not possible to configure the [crypto ipsec security-association multi-sn] command per peer. This command is a global configuration command that enables or disables the use of multiple SAs for a single IPsec peer.
Best regards
under the crypto map for that peer there is
set security-association multi-sn
 this way you can apply this command only for this peer
I am using VTI's and there is no this set command under ipsec profile
OK let me check how we can solve issue.
What about this command
Not in global mode but under the interface tunnel interface?
Best regards
there is no this command in interface mode, only crypto ipsec df-bit and fragmentation
ok the anti-reply issue can solve via three
1- disable anti-reply
2- change the size of window
3- config multi-seq num
why you can not use one of above two solution ?
Well
1. I want to keep anti-reply protection
2. Max windows size does not help
3. I do not want to change this on few hundered locations
But looks like problem is mybe in qos/VTI combination so I will try to move qos policy from physical interface to tunnel
understood,
this command in in IOS XE, I need to return home and check CSR.
update you soon.
I use CSr1000 IOS XE and there is set multi-sn under ipsec profile
please check above
well on ASR 1001-x  ios xe 17.06.03a there is not
(config-crypto-map)#set sec
(config-crypto-map)#set security-association ?
dfbit Handling of encapsulated DF bit.
dummy Enable transmitting dummy packets
ecn Handling of ECN bit
idle-time Automatically delete IPSec SAs after a given idle period.
level specify a security association granularity level for identities
lifetime security association lifetime
replay Set replay checking.
I think I found solution but I need to check some command reference first.
Did you ever figure this out?
can you please make new post
thanks
MHM
