CSCsi25051 Bug
bjornarsb
Level 4
Level 4
Does anyone have a workaround , or another ios that works ?
"packets get process switched instead of fast switched when
testing IKE/IPSEC. "
We're running c870-adventerprisek9-mz.124-9.T1.bin, and I can't se that packets are cef switched.
BR,
Bjornarsb
paolo bevilacqua
The bug seems to be recent and has been assigned already. It should not impact practical operation of the router, but if you want a more expeditious solution, open a TAC case and ask the engineer to link your case against this bug.
