Minimum memory requirements.
syroparmy
Which are the minimum memory requirements for a router running OSPF in a WAN consisting of 45 of them?
Amit Singh
Well, it depends on how big the routing table is.It also depends on the type of OSPF design you are making. For example if you have using the hierarchical design using the areas then Stub area or totally stub area routers dont need high memory on them. I would look atleast 128MB DRAM on the routers to run OSPF and other services on it.
http://www.cisco.com/en/US/tech/tk365/tk480/tsd_technology_support_sub-protocol_home.html
HTH,Please rate if it does.
-amit singh
Amit Singh
-amit singh
bjornarsb
Level 4
Level 4
Hard to tell , not knowing type of router nor
other features you want running. :)
The best way is to use Software Advisor:
http://www.cisco.com/en/US/support/tsd_most_requested_tools.html
BR,
Bjornarsb
