ā01-18-2021 08:13 AM
I'm experiencing the following issue:
We've got a Csr 1000v to test out vCUBE as a local gateway for Webex Calling.
After installing the license it shows up as "Active, Not in Use " and the voice features we need are not active.
The command license boot level does not show the ax license. Booting with advanced, premium or standard does not give us the features we need.
Below an output from the terminal for what mentioned above:
Router(config)#license boot level ?
advanced Advanced License Level
premium Premium License Level
standard Standard License Level
Router(config)#license boot level ax
% Invalid input detected at '^' marker. Follows a show license detail output:
Router#show license detail
Index: 1 Feature: ax_2500M Version: 1.0
License Type: Permanent
Start Date: N/A, End Date: Mar 13 2021
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Index: 2 Feature: prem_eval Version: 1.0
License Type: Evaluation
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 7 weeks 4 days
Period used: 6 days 3 hours
Expiry date: Mar 13 2021 12:23:19
License Priority: Low
Store Index: 0
Store Name: Built-In License Storage
As you can see the license shows as "Not in Use"
I have tried, as suggested by previous posts, to do license accept end user agreement followed by reload, but it yields no results
Router(config)#license accept end user agreement Router(config)#
I've also tried, as suggested in previous posts, to use license right-to-use move <license name>, but to no avail
Router#license right-to-use move ax_2500M
% No such Right To Use license
Router#
Can anybody help me out ?
Thanks in advance for the support!!
Solved! Go to Solution.
ā01-19-2021 01:38 AM
as per my understatnding you have -
Cisco IOS XE Software, Version 03.11.00.S
but you need
IOS XE 3.13.X later for AX License to get activated.
ā01-18-2021 08:49 AM
post show verion
ā01-19-2021 12:41 AM - edited ā01-19-2021 12:47 AM
Here you go:
Cisco IOS XE Software, Version 03.11.00.S - Standard Support Release
Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(1)S, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 19-Nov-13 21:00 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc. All rights reserved. Certain components of Cisco IOS-XE software are licensed under the GNU General Public License ("GPL") Version 2.0. The software code licensed under GPL Version 2.0 is free software that comes with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such GPL code under the terms of GPL Version 2.0. For more details, see the documentation or "License Notice" file accompanying the IOS-XE software, or the applicable URL provided on the flyer accompanying the IOS-XE software. ROM: IOS-XE ROMMON TDCube uptime is 16 hours, 47 minutes Uptime for this control processor is 16 hours, 48 minutes System returned to ROM by reload System image file is "bootflash:packages.conf" Last reload reason: Reload Command This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. License Level: advanced License Type: Evaluation License Next reload license Level: advanced cisco CSR1000V (VXE) processor with 2173577K/6147K bytes of memory. Processor board ID 96NM14KXYE8 1 Gigabit Ethernet interface 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 20357119K bytes of virtual hard disk at bootflash:. Configuration register is 0x2102
but you need
