csr 1000v low throughput & high CPU usage
Serg_tsk
We have virtual router Cisco CSR 1000v in a cloud. There are 8 vCPU, based on Intel Xeon E5-2660 v3 (2,6 GHz). We have 1Gbit/sec license and heavy data-plane cpu template:
csr1000v#show platform software cpu alloc
CPU alloc information:
  Control plane cpu alloc: 0
  Data plane cpu alloc: 1-7
  Service plane cpu alloc: 0
  Template used: None
Our problem is low network throughput with DMVPN + IPSEC tunnels. I didn't saw network speed more than 650 mbit\sec and the CPU usage in that situation is full:
CPU utilization for five seconds: 77%, one minute: 77%, five minutes: 77%
Core 0: CPU utilization for five seconds:  1%, one minute:  1%, five minutes:  1%
Core 1: CPU utilization for five seconds: 100%, one minute: 99%, five minutes: 99%
Core 2: CPU utilization for five seconds: 100%, one minute: 99%, five minutes: 99%
Core 3: CPU utilization for five seconds: 100%, one minute: 99%, five minutes: 99%
Core 4: CPU utilization for five seconds: 100%, one minute: 99%, five minutes: 99%
Core 5: CPU utilization for five seconds: 100%, one minute: 99%, five minutes: 99%
Core 6: CPU utilization for five seconds: 17%, one minute: 18%, five minutes: 18%
Core 7: CPU utilization for five seconds: 99%, one minute: 99%, five minutes: 99%
   Pid    PPid    5Sec    1Min    5Min  Status        Size  Name
 22424   21934    624%    624%    621%  R       1176592384  ucode_pkt_PPE0
csr1000v#show platform hardware qfp active datapath utilization summary
  CPP 0:                     5 secs        1 min        5 min       60 min
Input:     Total (pps)        68889        68538        52964        41879
                 (bps)    663208264    658867352    464399304    409978144
Output:    Total (pps)        68857        68538        52963        41880
                 (bps)    641941992    638171736    462007992    397564136
Processing: Load (pct)           99           99           72           63
Network speed become ~750 mbit/sec if I remove crypto and send packets with 1350 bytes length.
Tunnel and crypto configuration:
interface Tunnel200
  bandwidth 10000
 ip address 10.10.200.229 255.255.252.0
 no ip redirects
 ip mtu 1396
 ip bandwidth-percent eigrp 1 100
 ip nhrp authentication <secret>
 ip nhrp map 10.10.200.1 9.9.9.9
 ip nhrp map multicast 9.9.9.9
 ip nhrp network-id 200
 ip nhrp nhs 10.10.200.1
 ip tcp adjust-mss 1356
 delay 1050
 tunnel mode gre multipoint
 tunnel key 200
 tunnel path-mtu-discovery
tunnel protection ipsec profile <profile-name> shared
crypto ipsec transform-set <ts-name> esp-3des esp-sha-hmac
 mode transport
crypto ipsec profile <profile-name>
set transform-set <ts-name>
set pfs group5
I tried to use AES-256 crypto,  but the result was the same as with 3des.
Our service provider cant offer any ways of elimination this problem. Can i obtaint 1 Gbit/sec throughput in this case ? Thank you.
With best regards,
Sergey Kanovskiy.
20 Replies 20
post the output of:
show process cpu platform sorted
as well as the running configuration of the CSR1000v.
Hi! This is output from csr1000v :
csr1000v#show proc cpu sorted
CPU utilization for five seconds: 0%/0%; one minute: 0%; five minutes: 0%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   9      524504      231936       2261  0.39%  0.05%  0.00%   0 Check heaps
 103      214110    17024647         12  0.07%  0.01%  0.00%   0 100ms check
 186      483666    26596797         18  0.07%  0.03%  0.01%   0 VRRS Main thread
 195      546139    53038999         10  0.07%  0.03%  0.01%   0 IPAM Manager
 198      517459    53038999          9  0.07%  0.03%  0.00%   0 IP ARP Retry Age
 213       81449     6650286         12  0.07%  0.00%  0.00%   0 SSS Feature Time
   1           1          40         25  0.00%  0.00%  0.00%   0 Chunk Manager
   2       71453      340496        209  0.00%  0.00%  0.00%   0 Load Meter
   3           0           1          0  0.00%  0.00%  0.00%   0 XOS async sync X
   4           0           1          0  0.00%  0.00%  0.00%   0 Retransmission o
   5           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
   6           3          12        250  0.00%  0.00%  0.00%   0 RF Slave Main Th
   7           0           1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   8           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  10        1524       28391         53  0.00%  0.00%  0.00%   0 Pool Manager
  11           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  12           0           2          0  0.00%  0.00%  0.00%   0 Timers
  13          11        3812          2  0.00%  0.00%  0.00%   0 WATCH_AFS
  14       11427      851200         13  0.00%  0.00%  0.00%   0 IOSXE heartbeat
  15           0           2          0  0.00%  0.00%  0.00%   0 DB Lock Manager
  16           0           1          0  0.00%  0.00%  0.00%   0 DB Notification
  18           0           1          0  0.00%  0.00%  0.00%   0 VACS Background
  19           0           2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  20           0           2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Apps Task
  22           0           1          0  0.00%  0.00%  0.00%   0 ifIndex Receive
  23        1806      340488          5  0.00%  0.00%  0.00%   0 IPC Event Notifi
  24       17757     1662417         10  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  25           0           1          0  0.00%  0.00%  0.00%   0 Platform appsess
  26         214       28375          7  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  27        1574      340488          4  0.00%  0.00%  0.00%   0 IPC Service NonC
  28           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  29       18522     1662417         11  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  30       15467     1662416          9  0.00%  0.00%  0.00%   0 IPC Deferred Por
  31           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  32           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  33         836       97285          8  0.00%  0.00%  0.00%   0 IPC Check Queue
  34           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  35           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  36        5499      170249         32  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  37       16239      340488         47  0.00%  0.00%  0.00%   0 IPC Loadometer
  38           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Deta
  39           0           1          0  0.00%  0.00%  0.00%   0 SENSOR-MGR event
  40       23323      231384        100  0.00%  0.00%  0.00%   0 ARP Input
  41       23487     1775740         13  0.00%  0.00%  0.00%   0 ARP Background
  42           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  43           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  44           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  45           0           4          0  0.00%  0.00%  0.00%   0 DDR Timers
  46           3           3       1000  0.00%  0.00%  0.00%   0 Entity MIB API
  47          49           5       9800  0.00%  0.00%  0.00%   0 PrstVbl
  48           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  49           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  50           0           1          0  0.00%  0.00%  0.00%   0 MEMLEAK PROCESS
  51           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  52           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  53           0           1          0  0.00%  0.00%  0.00%   0 IOSXE signals IO
  54       18972     1702476         11  0.00%  0.00%  0.00%   0 GraphIt
  55           0           1          0  0.00%  0.00%  0.00%   0 License IPC stat
  56           0           1          0  0.00%  0.00%  0.00%   0 License IPC serv
  57           1         178          5  0.00%  0.00%  0.00%   0 Net Input
  58           0           1          0  0.00%  0.00%  0.00%   0 client_entity_se
  59           0           1          0  0.00%  0.00%  0.00%   0 RF SCTPthread
  60           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  61           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  62           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  63          33         198        166  0.00%  0.00%  0.00%   0 crypto sw pk pro
  64         158          44       3590  0.00%  0.00%  0.00%   0 License Client N
  65      147476       56746       2598  0.00%  0.00%  0.00%   0 Licensing Auto U
  66           0           1          0  0.00%  0.00%  0.00%   0 License HA Consi
  67           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  68           2           7        285  0.00%  0.00%  0.00%   0 SAStorage
  69           0           4          0  0.00%  0.00%  0.00%   0 SASConnect
  70       15505      892883         17  0.00%  0.00%  0.00%   0 SASRcvWQ
  71           1           5        200  0.00%  0.00%  0.00%   0 SACConnect
  72        7639      892893          8  0.00%  0.00%  0.00%   0 SACRcvWQ
  73           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  74       29589     1137227         26  0.00%  0.00%  0.00%   0 Net Background
  75           0           3          0  0.00%  0.00%  0.00%   0 IDB Work
  76       10074      758191         13  0.00%  0.00%  0.00%   0 Logger
  77       31405     1702284         18  0.00%  0.00%  0.00%   0 TTY Background
  78          24           4       6000  0.00%  0.00%  0.00%   0 CTS CORE
  79           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
  80           0           5          0  0.00%  0.00%  0.00%   0 SACRcvWQWrk1
  81           5          71         70  0.00%  0.00%  0.00%   0 SXP CORE
  82      261330     3112349         83  0.00%  0.00%  0.00%   0 IOSD ipc task
  83        1669      341917          4  0.00%  0.00%  0.00%   0 IOSD chasfs task
  84           1           2        500  0.00%  0.00%  0.00%   0 Crimson flush tr
  85         107        2839         37  0.00%  0.00%  0.00%   0 Cloud HA
  86        2691      243208         11  0.00%  0.00%  0.00%   0 REDUNDANCY FSM
  87           0           1          0  0.00%  0.00%  0.00%   0 Punt FP Stats Du
  88       89549      851136        105  0.00%  0.00%  0.00%   0 PuntInject Keepa
  89           0           6          0  0.00%  0.00%  0.00%   0 IF-MGR control p
  90           0          17          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  91           0           2          0  0.00%  0.00%  0.00%   0 CTS HA
  92           0           2          0  0.00%  0.00%  0.00%   0 CTS HA IPC flow
  93           0           1          0  0.00%  0.00%  0.00%   0 CTS HA operation
  94       13973     1702291          8  0.00%  0.00%  0.00%   0 Environmental Mo
  95       13769     1702291          8  0.00%  0.00%  0.00%   0 RP HA Periodic
  96           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  97           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  98           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
  99           0           1          0  0.00%  0.00%  0.00%   0 CONSOLE helper p
 100           9          16        562  0.00%  0.00%  0.00%   0 DBAL EVENTS
 101           0           1          0  0.00%  0.00%  0.00%   0 CEF RRP RF waite
 102       22468     1702323         13  0.00%  0.00%  0.00%   0 REDUNDANCY peer
 104           0           4          0  0.00%  0.00%  0.00%   0 ANCP HA
 105           0           2          0  0.00%  0.00%  0.00%   0 ANCP HA IPC flow
 106           0           1          0  0.00%  0.00%  0.00%   0 QoS HA ID RETAIN
 107           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 108           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 109           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 110           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 111           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 112           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 113           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 114           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 115           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 116           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 117           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
 118           0           1          0  0.00%  0.00%  0.00%   0 Network-rf Notif
 119           0           3          0  0.00%  0.00%  0.00%   0 ARP HA
 120           0           1          0  0.00%  0.00%  0.00%   0 XDR RRP RF waite
 121      130247     2433754         53  0.00%  0.00%  0.00%   0 IOSXE-RP Punt Se
 122           0           1          0  0.00%  0.00%  0.00%   0 IOSXE-RP Punt IP
 123           0           1          0  0.00%  0.00%  0.00%   0 ACL Log Punt Ser
 124           0           1          0  0.00%  0.00%  0.00%   0 ACL deny punt se
 125           0           1          0  0.00%  0.00%  0.00%   0 OFSDN Punject Pr
 126           0           1          0  0.00%  0.00%  0.00%   0 IOSXE-RP QFP HA
 127           0           1          0  0.00%  0.00%  0.00%   0 DHCPC HA
 128           0           1          0  0.00%  0.00%  0.00%   0 DHCPD HA
 129           0           1          0  0.00%  0.00%  0.00%   0 DHCPv6 Relay HA
 130           0           1          0  0.00%  0.00%  0.00%   0 DHCPv6 Server HA
 131           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
 132           0           1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
 133           0           1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
 134           3          12        250  0.00%  0.00%  0.00%   0 RF Master Main T
 135           0           7          0  0.00%  0.00%  0.00%   0 RF Master Status
 136           0           6          0  0.00%  0.00%  0.00%   0 SASRcvWQWrk1
 137         237       41741          5  0.00%  0.00%  0.00%   0 SACRcvWQWrk2
 138        1010       41739         24  0.00%  0.00%  0.00%   0 SASRcvWQWrk2
 139        6099      170250         35  0.00%  0.00%  0.00%   0 Compute load avg
 140      180360       56749       3178  0.00%  0.00%  0.00%   0 Per-minute Jobs
 141       41509     1702477         24  0.00%  0.00%  0.00%   0 Per-Second Jobs
 142          14         742         18  0.00%  0.00%  0.00%   0 Transport Port A
 143           0           1          0  0.00%  0.00%  0.00%   0 IOSXE-RP FastPat
 144       15430     1662413          9  0.00%  0.00%  0.00%   0 fanrp_l2fib
 145           0           2          0  0.00%  0.00%  0.00%   0 FEC_Link_event_h
 146           0           1          0  0.00%  0.00%  0.00%   0 BFD HW EVENT
 147           0           1          0  0.00%  0.00%  0.00%   0 BFD IPV6 ADDR CH
 148           2           4        500  0.00%  0.00%  0.00%   0 EEM ED MAT
 149           0          35          0  0.00%  0.00%  0.00%   0 EEM ED ND
 150           0           1          0  0.00%  0.00%  0.00%   0 SSLVPN Register
 151       19581      191323        102  0.00%  0.00%  0.00%   0 IPSec background
 152      264278     8507733         31  0.00%  0.01%  0.00%   0 ONEP Network Ele
 153        7456      340479         21  0.00%  0.00%  0.00%   0 vNIC stats Proce
 154          28           2      14000  0.00%  0.00%  0.00%   0 CWAN OIR Handler
 155           0           1          0  0.00%  0.00%  0.00%   0 TP CUTOVER EVENT
 156        7272      567475         12  0.00%  0.00%  0.00%   0 ACE event
 157        2909       76570         37  0.00%  0.00%  0.00%   0 ACE HAPI
 158         135       14188          9  0.00%  0.00%  0.00%   0 ACE policy loade
 159           0           1          0  0.00%  0.00%  0.00%   0 RTTYS Process
 160       10242      432724         23  0.00%  0.00%  0.00%   0 EIGRP-IPv4
 161           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
 162           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
 163           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
 164           0           1          0  0.00%  0.00%  0.00%   0 PPCP RP Stats Ba
 165           0           1          0  0.00%  0.00%  0.00%   0 L2FIB Timer Disp
 166           0           2          0  0.00%  0.00%  0.00%   0 IGMP Route Msg H
 167           0           1          0  0.00%  0.00%  0.00%   0 IGMP Route Rx Pr
 168           0           1          0  0.00%  0.00%  0.00%   0 MLRIB L2 Msg Thr
 169           0           1          0  0.00%  0.00%  0.00%   0 TEMPLATE HA
 170           0           1          0  0.00%  0.00%  0.00%   0 DVLAN HA
 171           0           1          0  0.00%  0.00%  0.00%   0 RABAPOL HA
 172           0           2          0  0.00%  0.00%  0.00%   0 RABAPOL HA IPC f
 173           0           2          0  0.00%  0.00%  0.00%   0 RG Faults Timer
 174           0           1          0  0.00%  0.00%  0.00%   0 RG VP
 175           0           2          0  0.00%  0.00%  0.00%   0 RG AR
 176           0           2          0  0.00%  0.00%  0.00%   0 RG Protocol Time
 177           0           2          0  0.00%  0.00%  0.00%   0 RG Transport Tim
 178           0           1          0  0.00%  0.00%  0.00%   0 HDLC HA
 179           0           5          0  0.00%  0.00%  0.00%   0 EPM IAL Process
 180           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
 181           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
 182       34356     1702288         20  0.00%  0.00%  0.00%   0 FHRP Main thread
 183        8459      340487         24  0.00%  0.00%  0.00%   0 TRACK Main threa
 184           1           2        500  0.00%  0.00%  0.00%   0 TRACK Client thr
 185           0           1          0  0.00%  0.00%  0.00%   0 VRRP Main thread
 187           0           1          0  0.00%  0.00%  0.00%   0 HQF TARGET DYNAM
 188           0           1          0  0.00%  0.00%  0.00%   0 IEDGE ACCT TIMER
 189           0           1          0  0.00%  0.00%  0.00%   0 ISG CMD HANDLER
 190           0           2          0  0.00%  0.00%  0.00%   0 IP PORTBUNDLE
 191        2052      415644          4  0.00%  0.00%  0.00%   0 IP Static Sessio
 192           0           2          0  0.00%  0.00%  0.00%   0 DVLAN Config Pro
 193        3980      415644          9  0.00%  0.00%  0.00%   0 IP Lite session
 194           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
 196           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
 197           2          11        181  0.00%  0.00%  0.00%   0 IP ARP Adjacency
 199        1513       42328         35  0.00%  0.00%  0.00%   0 IP Input
 200           0           1          0  0.00%  0.00%  0.00%   0 ICMP event handl
 201       18066     1702288         10  0.00%  0.00%  0.00%   0 mDNS
 202           0           1          0  0.00%  0.00%  0.00%   0 Policy bind Proc
 203           0           1          0  0.00%  0.00%  0.00%   0 AAA EPD HANDLER
 204           0           1          0  0.00%  0.00%  0.00%   0 PM EPD API
 205           0           1          0  0.00%  0.00%  0.00%   0 DM Proc
 206           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
 207           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
 208           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
 209           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
 210         229       28375          8  0.00%  0.00%  0.00%   0 SSS Manager
 211           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
 212           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
 214           0           1          0  0.00%  0.00%  0.00%   0 SSS PM SHIM QOS
 215           0           1          0  0.00%  0.00%  0.00%   0 LONG TO SHORT NA
 216           0           1          0  0.00%  0.00%  0.00%   0 Timer handler fo
 217           0           1          0  0.00%  0.00%  0.00%   0 Prepaid response
 218           0           1          0  0.00%  0.00%  0.00%   0 Timed Policy act
 219           0           1          0  0.00%  0.00%  0.00%   0 AAA response han
 220        1433      113499         12  0.00%  0.00%  0.00%   0 Spanning Tree
 221           0           2          0  0.00%  0.00%  0.00%   0 SpanTree Msg
 222      163861    13290393         12  0.00%  0.01%  0.00%   0 Tunnel BGP
 223           0           1          0  0.00%  0.00%  0.00%   0 VRRS
 224          49        5675          8  0.00%  0.00%  0.00%   0 Appnav auto disc
 225       10750     1702288          6  0.00%  0.00%  0.00%   0 cdp init process
 226         731       28375         25  0.00%  0.00%  0.00%   0 Call Home Timer
 227           2         182         10  0.00%  0.00%  0.00%   0 AAA Server
 228           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
 229           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
 230           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
 231           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
 232           0           1          0  0.00%  0.00%  0.00%   0 PKI Trustpool
 233           0           1          0  0.00%  0.00%  0.00%   0 RADIUS Proxy
 234           0           1          0  0.00%  0.00%  0.00%   0 radius radsec cl
 235           0           2          0  0.00%  0.00%  0.00%   0 SNMP DBAL WRAPPE
 236           0           1          0  0.00%  0.00%  0.00%   0 SNMP DBAL Cache
 237           0           1          0  0.00%  0.00%  0.00%   0 SNMP DBAL Cache
 238           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
 239       30081     1662559         18  0.00%  0.00%  0.00%   0 L2RIB Thread
 240           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
 241           0           2          0  0.00%  0.00%  0.00%   0 RIB LM VALIDATE
 242           0           1          0  0.00%  0.00%  0.00%   0 XDR background p
 243         392       28375         13  0.00%  0.00%  0.00%   0 XDR mcast
 244           0           1          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
 245           0           1          0  0.00%  0.00%  0.00%   0 XDR receive
 246           0           1          0  0.00%  0.00%  0.00%   0 IPC LC Message H
 247           0           1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
 248         194       28375          6  0.00%  0.00%  0.00%   0 FRR Background P
 249        3237      171544         18  0.00%  0.00%  0.00%   0 CEF background p
 250           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
 251           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
 252           0           1          0  0.00%  0.00%  0.00%   0 CEF RP Backgroun
 253           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
 254        4499       14595        308  0.00%  0.00%  0.00%   0 IP RIB Update
 255         308       28396         10  0.00%  0.00%  0.00%   0 IP Background
 256           1          47         21  0.00%  0.00%  0.00%   0 IP Connected Rou
 257           0           1          0  0.00%  0.00%  0.00%   0 Tunnel FIB
 258       15369     1702288          9  0.00%  0.00%  0.00%   0 nbar-graph-sende
 259        4474      340488         13  0.00%  0.00%  0.00%   0 nbar-custom-prot
 260         502       28376         17  0.00%  0.00%  0.00%   0 nbar-auto-custom
 261       30074     1702287         17  0.00%  0.00%  0.00%   0 nbar-sdavc-sched
 262         446       28376         15  0.00%  0.00%  0.00%   0 nbar-pp-monitor
 263           0           2          0  0.00%  0.00%  0.00%   0 EFP Errd
 264           1           2        500  0.00%  0.00%  0.00%   0 Ether EFP Proces
 265           0           2          0  0.00%  0.00%  0.00%   0 Ether Infra RP
 266           0           2          0  0.00%  0.00%  0.00%   0 CFM HA IPC messa
 267           0           1          0  0.00%  0.00%  0.00%   0 Ethernet PM Proc
 268           0           2          0  0.00%  0.00%  0.00%   0 Ethernet PM Soft
 269        4529      510594          8  0.00%  0.00%  0.00%   0 Ethernet PM Moni
 270           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
 271          61       12256          4  0.00%  0.00%  0.00%   0 TCP Timer
 272          23         909         25  0.00%  0.00%  0.00%   0 TCP Protocols
 273           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
 274          65        5678         11  0.00%  0.00%  0.00%   0 HTTP CORE
 275           0          21          0  0.00%  0.00%  0.00%   0 IGMPSN L2MCM
 276           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN MRD
 277           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN
 278           0           1          0  0.00%  0.00%  0.00%   0 TCP HA PROC
 279           0           2          0  0.00%  0.00%  0.00%   0 Tunnel
 280        6446      851151          7  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
 281           9         681         13  0.00%  0.00%  0.00%   0 ADJ background
 282          24        1374         17  0.00%  0.00%  0.00%   0 Collection proce
 283           0           1          0  0.00%  0.00%  0.00%   0 RETRY_REPOPULATE
 284           0           2          0  0.00%  0.00%  0.00%   0 XDR FOF process
 285           0          23          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
 286           0           2          0  0.00%  0.00%  0.00%   0 Flow Exporter Pa
 287           0           2          0  0.00%  0.00%  0.00%   0 L2FIB Event Disp
 288           0           1          0  0.00%  0.00%  0.00%   0 IGMPQR
 289           0           2          0  0.00%  0.00%  0.00%   0 App Route Proces
 290           0           1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Cleanup
 291           0           1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
 292           0           1          0  0.00%  0.00%  0.00%   0 ATM HA
 293           0           2          0  0.00%  0.00%  0.00%   0 ATM HA IPC flow
 294           0          24          0  0.00%  0.00%  0.00%   0 EVPN Mgr Thread
 295           0           1          0  0.00%  0.00%  0.00%   0 FR HA
 296           0           2          0  0.00%  0.00%  0.00%   0 GLBP HA
 297           0           1          0  0.00%  0.00%  0.00%   0 Probe Input
 298           0           2          0  0.00%  0.00%  0.00%   0 HSRP HA
 299           0           2          0  0.00%  0.00%  0.00%   0 RBSCP Background
 300           0           2          0  0.00%  0.00%  0.00%   0 SNMP Timers
 301           0           1          0  0.00%  0.00%  0.00%   0 RG If-Mgr Timer
 302           0           2          0  0.00%  0.00%  0.00%   0 RG Media Timer
 303           0           2          0  0.00%  0.00%  0.00%   0 VRRP HA
 304           0           1          0  0.00%  0.00%  0.00%   0 IOSXE-RP Punt Qo
 305           4           4       1000  0.00%  0.00%  0.00%   0 MCPRP RG Timer
 306           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
 307           0           2          0  0.00%  0.00%  0.00%   0 VTEMPLATE IPC fl
 308           0           1          0  0.00%  0.00%  0.00%   0 BFD HA
 309           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
 310           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
 311           0           3          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
 312           0           1          0  0.00%  0.00%  0.00%   0 COPS
 313           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
 314           0           3          0  0.00%  0.00%  0.00%   0 Service Routing
 315           1          27         37  0.00%  0.00%  0.00%   0 SR CapMan Proces
 316        2450      415644          5  0.00%  0.00%  0.00%   0 IP SIP Process
 317           0           2          0  0.00%  0.00%  0.00%   0 IP Inband Sessio
 318           0          18          0  0.00%  0.00%  0.00%   0 DNS Service
 319           4         178         22  0.00%  0.00%  0.00%   0 RARP Input
 320           0          21          0  0.00%  0.00%  0.00%   0 static
 321           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
 322           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
 323           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
 324           0           2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
 325           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
 326           1           2        500  0.00%  0.00%  0.00%   0 AN
 327           0           1          0  0.00%  0.00%  0.00%   0 AN HELPER
 328           0           1          0  0.00%  0.00%  0.00%   0 AN CONFIG DOWNLO
 329       34573     3324498         10  0.00%  0.00%  0.00%   0 Inspect process
 330        1633      286000          5  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
 331           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
 332           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
 333           0           1          0  0.00%  0.00%  0.00%   0 DHCP SIP
 334           1           2        500  0.00%  0.00%  0.00%   0 DHCPv6 LQ client
 335           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ACL RP Proc
 336           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Static Hand
 337        4692      170247         27  0.00%  0.00%  0.00%   0 QoS stats proces
 338           0           1          0  0.00%  0.00%  0.00%   0 EVPN HA Bulk Syn
 339           0          19          0  0.00%  0.00%  0.00%   0 MVPN Mgr Process
 340           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
 341           9         475         18  0.00%  0.00%  0.00%   0 SSH Event handle
 342           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 343           0           1          0  0.00%  0.00%  0.00%   0 MRIB RP PROCESS
 344           0           1          0  0.00%  0.00%  0.00%   0 MRIB RP Proxy
 345          81        5585         14  0.00%  0.00%  0.00%   0 MFIB Master back
 346           0           1          0  0.00%  0.00%  0.00%   0 BGP HA SSO
 347       40606     3324498         12  0.00%  0.00%  0.00%   0 TLSCLIENT_PROCES
 348           0           1          0  0.00%  0.00%  0.00%   0 SSL background p
 349           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
 350           0           2          0  0.00%  0.00%  0.00%   0 HTTP Process
 351           2           2       1000  0.00%  0.00%  0.00%   0 DynCmd Package P
 352           0           2          0  0.00%  0.00%  0.00%   0 Diameter Base pr
 353           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
 354           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
 355           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
 356        2902       29245         99  0.00%  0.00%  0.00%   2 SSH Process
 357           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
 358           0           3          0  0.00%  0.00%  0.00%   0 EST Client
 359           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
 360           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
 361           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
 362           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
 363          46        5475          8  0.00%  0.00%  0.00%   0 LOCAL AAA
 364           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
 365           0           1          0  0.00%  0.00%  0.00%   0 Opaque Database
 366       49376     3324502         14  0.00%  0.00%  0.00%   0 Timer Library
 367           0          16          0  0.00%  0.00%  0.00%   0 Crypto Support
 368           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
 369           0           1          0  0.00%  0.00%  0.00%   0 EAP Process
 370         130         473        274  0.00%  0.00%  0.00%   0 NIST rng proc
 371           0           2          0  0.00%  0.00%  0.00%   0 File Copy Handle
 372           0           2          0  0.00%  0.00%  0.00%   0 COND_DEBUG HA IP
 373           0           1          0  0.00%  0.00%  0.00%   0 AAA Proxy
 374           0           1          0  0.00%  0.00%  0.00%   0 TPS IPC Process
 375        1707      154479         11  0.00%  0.00%  0.00%   0 crypto engine pr
 376           0           1          0  0.00%  0.00%  0.00%   0 RSA background p
 377          44        1895         23  0.00%  0.00%  0.00%   0 Crypto CA
 378           0           3          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
 379           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-Rev-P
 380           0           1          0  0.00%  0.00%  0.00%   0 PKI OCSP
 381           0           1          0  0.00%  0.00%  0.00%   0 PKI Revocation
 382           0           1          0  0.00%  0.00%  0.00%   0 QOS PERUSER
 383           0           2          0  0.00%  0.00%  0.00%   0 PIM HA
 384       44956     1759000         25  0.00%  0.00%  0.00%   0 Crypto IKEv2
 385           0           1          0  0.00%  0.00%  0.00%   0 IKEv2 AAA handle
 386           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
 387         416       51264          8  0.00%  0.00%  0.00%   0 CRYPTO MAP FREE
 388           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
 389       34963      797864         43  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
 390      589485     3146638        187  0.00%  0.04%  0.02%   0 Crypto IKMP
 391           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
 392           0           1          0  0.00%  0.00%  0.00%   0 IPsec vesen keym
 393       18234      278166         65  0.00%  0.00%  0.00%   0 IPSEC key engine
 394           0           1          0  0.00%  0.00%  0.00%   0 Crypto ACL
 395           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
 396           0           2          0  0.00%  0.00%  0.00%   0 GKM GM Process
 397           0           1          0  0.00%  0.00%  0.00%   0 GKM KS PROCESS
 398           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
 400        3145       56751         55  0.00%  0.00%  0.00%   0 Flash low disk s
 401       14030      625779         22  0.00%  0.00%  0.00%   0 EIGRP-IPv4
 402           0           2          0  0.00%  0.00%  0.00%   0 ICRM
 403           0           1          0  0.00%  0.00%  0.00%   0 Online Diag EEM
 404         244       28375          8  0.00%  0.00%  0.00%   0 SPA ENTITY Proce
 405           0           1          0  0.00%  0.00%  0.00%   0 dcm_cli_engine
 406           0           3          0  0.00%  0.00%  0.00%   0 dcm_cli_provider
 407           1           4        250  0.00%  0.00%  0.00%   0 DCM Core Thread
 408        7799      446537         17  0.00%  0.00%  0.00%   0 EEM ED Syslog
 409           1           4        250  0.00%  0.00%  0.00%   0 EEM ED Generic
 410           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Track
 411           1           4        250  0.00%  0.00%  0.00%   0 EEM ED Routing
 412           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Resource
 414           0           2          0  0.00%  0.00%  0.00%   0 MCPRP UTD Timer
 415           4         182         21  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 416           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
 417           0           1          0  0.00%  0.00%  0.00%   0 IKEv2 FlexVPN Pr
 418           0           1          0  0.00%  0.00%  0.00%   0 IKEv2 Cluster Lo
 419           0           1          0  0.00%  0.00%  0.00%   0 ISSU Utility Pro
 420           0           1          0  0.00%  0.00%  0.00%   0 IOSXE-RP Virtual
 422           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs ICMP Jit
 424           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
 425           1           3        333  0.00%  0.00%  0.00%   0 WSMAN Process
 426           0           1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
 427           0           1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
 428         505        1069        472  0.00%  0.00%  0.00%   0 DCM snmp dp Thre
 429           0           3          0  0.00%  0.00%  0.00%   0 snmp dcm ma shim
 430        2674      170250         15  0.00%  0.00%  0.00%   0 Bulkstat-Client
 431           0           3          0  0.00%  0.00%  0.00%   0 dcm_expression_p
 432           2         113         17  0.00%  0.00%  0.00%   0 EEM Server
 433           3          18        166  0.00%  0.00%  0.00%   0 Call Home proces
 434           0           1          0  0.00%  0.00%  0.00%   0 Call Home DS
 435           0           1          0  0.00%  0.00%  0.00%   0 Call Home DSfile
 436           0           3          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
 437           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 438           1           4        250  0.00%  0.00%  0.00%   0 EEM ED CLI
 439           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Counter
 440           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Interface
 441           0           4          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
 442           0           4          0  0.00%  0.00%  0.00%   0 EEM ED None
 443           0           4          0  0.00%  0.00%  0.00%   0 EEM ED OIR
 444           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RF
 445           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
 446           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
 447           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
 448         773       29202         26  0.00%  0.00%  0.00%   0 EEM ED Timer
 449           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Test
 450           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Config
 451           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Env
 452           0           4          0  0.00%  0.00%  0.00%   0 EEM ED DS
 453           0           4          0  0.00%  0.00%  0.00%   0 EEM ED CRASH
 454           0           4          0  0.00%  0.00%  0.00%   0 EM ED GOLD
 455        2483       16677        148  0.00%  0.00%  0.00%   0 Syslog
 457        3084      170246         18  0.00%  0.00%  0.00%   0 qos_mon_periodic
 458           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RPC
 459           1           6        166  0.00%  0.00%  0.00%   0 RBM CORE
 460           1           3        333  0.00%  0.00%  0.00%   0 CTS credentials
 461           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 462           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 463           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 464           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 465           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 466           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 467           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 468           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 469           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 470           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 471           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 472           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 473           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 474           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 475           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 476           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 477           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 478           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 479           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 480           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 481           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 482           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 483           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 484           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 485           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 486           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 487           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 488           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 489           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 490           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 491           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 492           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 493           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 494           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 495           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 496           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 497           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 498           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 499           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 500           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 501           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 502           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 503           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 504           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 505           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 506           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 507           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 508           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 509           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 510           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 511           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 512           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 513           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 514           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 515           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 516           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 517           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 518           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 519           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 520           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 521           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 522           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 523           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
 524       12304      103911        118  0.00%  0.00%  0.00%   0 mdns Timer Proce
 525           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
 526           1         143          6  0.00%  0.00%  0.00%   0 EEM Helper Threa
 527           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 529           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 530           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 531           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 532           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 533           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch po
 534           0           1          0  0.00%  0.00%  0.00%   0 ONEP Dispatch XD
 535       27582      330915         83  0.00%  0.00%  0.00%   0 NHRP
 536       57945     1105758         52  0.00%  0.00%  0.00%   0 Multicast Replic
 537       37933     3324509         11  0.00%  0.00%  0.00%   0 IP NAT Ager
 538           0           1          0  0.00%  0.00%  0.00%   0 IP VFR proc
 539        3300      152569         21  0.00%  0.00%  0.00%   0 Tunnel Security
 540       34387      151749        226  0.00%  0.00%  0.00%   0 Crypto SS Proces
 542       26566      566297         46  0.00%  0.00%  0.00%   0 IP SNMP
 543        9774      283229         34  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 544       45310      283232        159  0.00%  0.00%  0.00%   0 SNMP ENGINE
 545           0           2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
 546           0           1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
 547           0           2          0  0.00%  0.00%  0.00%   0 SNMP Traps
 548           0           1          0  0.00%  0.00%  0.00%   0 NAT MIB Helper
 549       48811     1730099         28  0.00%  0.00%  0.00%   0 NTP
 552           0           5          0  0.00%  0.00%  0.00%   0 EIGRP-IPv4
 553       38482      759677         50  0.00%  0.00%  0.00%   0 EIGRP-IPv4 Hello
 554       71859     1314503         54  0.00%  0.00%  0.00%   0 EIGRP-IPv4 Hello
 555           0           1          0  0.00%  0.00%  0.00%   0 EIGRP-IPv4 Hello
 556           0           1          0  0.00%  0.00%  0.00%   0 WSMA_NOTIFY
 557           0           1          0  0.00%  0.00%  0.00%   0 SEP_webui_wsma_h
 558           0           1          0  0.00%  0.00%  0.00%   0 SEP_webui_wsma_h
 559       50929      680894         74  0.00%  0.00%  0.00%   0 DiagCard1/-1
 560           0           2          0  0.00%  0.00%  0.00%   0 DiagCard2/-1
But in this time :
csr1000v#show proc cpu platform sorted
CPU utilization for five seconds: 72%, one minute: 71%, five minutes: 39%
Core 1: CPU utilization for five seconds: 90%, one minute: 92%, five minutes: 51%
Core 2: CPU utilization for five seconds: 90%, one minute: 92%, five minutes: 51%
Core 3: CPU utilization for five seconds: 90%, one minute: 92%, five minutes: 51%
Core 4: CPU utilization for five seconds: 91%, one minute: 94%, five minutes: 57%
Core 5: CPU utilization for five seconds: 90%, one minute: 92%, five minutes: 51%
Core 6: CPU utilization for five seconds: 15%, one minute: 16%, five minutes: 12%
Core 7: CPU utilization for five seconds: 89%, one minute: 91%, five minutes: 56%
 22424   21934    563%    578%    339%  R       1176592384  ucode_pkt_PPE0
 22694    7692      0%      0%      0%  S        152096768  vmtoolsd
 22622   15136      0%      0%      0%  R       5318287360  linux_iosd-imag
 22345   21262      0%      0%      0%  S       2227830784  fman_fp_image
 22152       1      0%      0%      0%  S         66916352  rotee
 21934   18311      0%      0%      0%  S         19496960  pman.sh
 21535   20877      0%      0%      0%  S       1068830720  cpp_sp_svr
 21527       1      0%      0%      0%  S         66916352  rotee
 21475   19781      0%      0%      0%  S       1716887552  cpp_cp_svr
 21262   18311      0%      0%      0%  S         19501056  pman.sh
 21182   20556      0%      0%      0%  S       1047699456  cpp_ha_top_leve
 21118       1      0%      0%      0%  S         66916352  rotee
 20877   18311      0%      0%      0%  S         19496960  pman.sh
 20834   20101      0%      0%      0%  S       1026043904  cpp_driver
 20782       1      0%      0%      0%  S         66916352  rotee
 20556   18311      0%      0%      0%  S         19496960  pman.sh
 20472       1      0%      0%      0%  S         66916352  rotee
 20101   18311      0%      0%      0%  S         19496960  pman.sh
 20088   19489      0%      0%      0%  S        878260224  cman_fp
 20016       1      0%      0%      0%  S         66916352  rotee
 19841   19193      0%      0%      0%  S        215998464  btman
 19781   18311      0%      0%      0%  S         19496960  pman.sh
 19694       1      0%      0%      0%  S         66916352  rotee
 19568       2      0%      0%      0%  S                0  kworker/u16:0
 19489   18311      0%      0%      0%  S         19496960  pman.sh
 19433       1      0%      0%      0%  S         66916352  rotee
 19193   18311      0%      0%      0%  S         19501056  pman.sh
 18840   18227      0%      0%      0%  S        355258368  vman
 18764   18311      0%      0%      0%  S          6877184  inotifywait
 18568       1      0%      0%      0%  S         67039232  rotee
 18398       1      0%      0%      0%  S         66916352  rotee
 18311       1      0%      0%      0%  S         21590016  pvp.sh
 18267   17925      0%      0%      0%  S         18800640  sort_files_by_i
 18227   13015      0%      0%      0%  S         19501056  pman.sh
 18201   17653      0%      0%      0%  S        657612800  smd
 18084       1      0%      0%      0%  S         66916352  rotee
 17925   13015      0%      0%      0%  S         19505152  pman.sh
 17872   17415      0%      0%      0%  S        496672768  smand
 17828       1      0%      0%      0%  S         66916352  rotee
 17655   17254      0%      0%      0%  S        316923904  repm
 17653   13015      0%      0%      0%  S         19501056  pman.sh
 17566       1      0%      0%      0%  S         66916352  rotee
 17415   13015      0%      0%      0%  S         19496960  pman.sh
 17365       1      0%      0%      0%  S         67039232  rotee
 17254   13015      0%      0%      0%  S         19496960  pman.sh
 17133   16510      0%      0%      0%  S        219795456  psd
 16883       1      0%      0%      0%  S         66916352  rotee
 16880   16846      0%      0%      0%  S         33345536  journalctl
 16846   16201      0%      0%      0%  S        186753024  plogd
 16510   13015      0%      0%      0%  S         19501056  pman.sh
 16435       1      0%      0%      0%  S         66920448  rotee
 16389       1      0%      0%      0%  S         67039232  rotee
 16338   15947      0%      0%      0%  S         23875584  periodic.sh
 16201   13015      0%      0%      0%  S         19505152  pman.sh
 16128   15680      0%      0%      0%  S        206798848  ofa
 16117       1      0%      0%      0%  S         66916352  rotee
 15947   13015      0%      0%      0%  S         19501056  pman.sh
 15904   15499      0%      0%      0%  S        260403200  lman
 15837       1      0%      0%      0%  S         66916352  rotee
 15680   13015      0%      0%      0%  S         19501056  pman.sh
 15605       1      0%      0%      0%  S         66916352  rotee
 15499   13015      0%      0%      0%  S         19501056  pman.sh
 15241       1      0%      0%      0%  S         66916352  rotee
 15136   13015      0%      0%      0%  S         19628032  pman.sh
 15108   14819      0%      0%      0%  R        243707904  hman
 14947   14427      0%      0%      0%  S       1348874240  fman_rp
 14936       1      0%      0%      0%  S         66916352  rotee
 14819   13015      0%      0%      0%  S         19501056  pman.sh
 14565       1      0%      0%      0%  S         66916352  rotee
 14513   14181      0%      0%      0%  S        228700160  emd
 14427   13015      0%      0%      0%  S         19496960  pman.sh
 14325       1      0%      0%      0%  S         66916352  rotee
 14282   13915      0%      0%      0%  S        674086912  dbm
 14181   13015      0%      0%      0%  S         19496960  pman.sh
 14076       1      0%      0%      0%  S         67039232  rotee
 14063   13622      0%      0%      0%  S        412176384  cmand
 13915   13015      0%      0%      0%  S         19501056  pman.sh
 13885   13391      0%      0%      0%  S        839643136  cli_agent
 13799       1      0%      0%      0%  S         66916352  rotee
 13693   13234      0%      0%      0%  S        216076288  btman
 13622   13015      0%      0%      0%  S         19501056  pman.sh
 13529       1      0%      0%      0%  S         67039232  rotee
 13391   13015      0%      0%      0%  S         19501056  pman.sh
 13344       1      0%      0%      0%  S         66916352  rotee
 13234   13015      0%      0%      0%  S         19496960  pman.sh
 13125   13015      0%      0%      0%  S          6877184  inotifywait
 13073       1      0%      0%      0%  S         67039232  rotee
 13015       1      0%      0%      0%  S         21729280  pvp.sh
 13006   12770      0%      0%      0%  S          6877184  inotifywait
 13003   12774      0%      0%      0%  S          6877184  inotifywait
 12984       1      0%      0%      0%  S         66916352  rotee
 12983       1      0%      0%      0%  S         67039232  rotee
 12774       1      0%      0%      0%  S         23920640  psvp.sh
 12771       1      0%      0%      0%  S         15577088  xinetd
 12770       1      0%      0%      0%  S         22237184  rollback_timer.
 12768       1      0%      0%      0%  S         15577088  xinetd
 11606       1      0%      0%      0%  S         15577088  xinetd
 11599       2      0%      0%      0%  S                0  kworker/1:2
 11592       1      0%      0%      0%  S         15577088  xinetd
 11169       2      0%      0%      0%  S                0  kworker/u16:2
 10310       1      0%      0%      0%  S          4685824  acpid
  9577    9526      0%      0%      0%  S         19062784  iodbd.sh
  9526       1      0%      0%      0%  T         18931712  iodbd.sh
  9384       2      0%      0%      0%  S                0  ena
  9151    7688      0%      0%      0%  S          6877184  inotifywait
  9013    7693      0%      0%      0%  S          6877184  inotifywait
  8898       2      0%      0%      0%  S                0  loop1
  8884       1      0%      0%      0%  S         67379200  rotee
  8854       1      0%      0%      0%  S         66916352  rotee
  8693    8386      0%      0%      0%  S          6877184  inotifywait
  8669       1      0%      0%      0%  S         66916352  rotee
  8514       1      0%      0%      0%  S         66916352  rotee
  8386       1      0%      0%      0%  S         20361216  iptbl.sh
  8059    7687      0%      0%      0%  S          4669440  sleep
  7903       1      0%      0%      0%  S         66916352  rotee
  7846       1      0%      0%      0%  S         15577088  xinetd
  7714    7699      0%      0%      0%  S        279855104  libvirtd
  7710       1      0%      0%      0%  S         16031744  rpc.statd
  7699       1      0%      0%      0%  S         18661376  libvirtd.sh
  7694       1      0%      0%      0%  S         32645120  rpcbind
  7693       1      0%      0%      0%  S         21573632  droputil.sh
  7692       1      0%      0%      0%  S         85868544  bhytoolsd
  7691       1      0%      0%      0%  S         49127424  virtlogd
  7688       1      0%      0%      0%  S         21569536  reflector.sh
  7687       1      0%      0%      0%  S         19202048  oom.sh
  7365       2      0%      0%      0%  S                0  lsmpi-rx
  7364       2      0%      0%      0%  S                0  lsmpi-xmit
  7363       2      0%      0%      0%  S                0  lsmpi-refill
  5096       2      0%      0%      0%  S                0  loop0
  4617       2      0%      0%      0%  S                0  bioset
  4616       2      0%      0%      0%  S                0  dmcrypt_write
  4615       2      0%      0%      0%  S                0  kcryptd
  4614       2      0%      0%      0%  S                0  kcryptd_io
  4612       2      0%      0%      0%  S                0  bioset
  4611       2      0%      0%      0%  S                0  kdmflush
  4600       2      0%      0%      0%  S                0  bioset
  4599       2      0%      0%      0%  S                0  dmcrypt_write
  4598       2      0%      0%      0%  S                0  kcryptd
  4597       2      0%      0%      0%  S                0  kcryptd_io
  4596       2      0%      0%      0%  S                0  bioset
  4595       2      0%      0%      0%  S                0  kdmflush
  4583       2      0%      0%      0%  S                0  bioset
  4582       2      0%      0%      0%  S                0  dmcrypt_write
  4581       2      0%      0%      0%  S                0  kcryptd
  4580       2      0%      0%      0%  S                0  kcryptd_io
  4579       2      0%      0%      0%  S                0  bioset
  4578       2      0%      0%      0%  S                0  kdmflush
  4566       2      0%      0%      0%  S                0  bioset
  4565       2      0%      0%      0%  S                0  dmcrypt_write
  4564       2      0%      0%      0%  S                0  kcryptd
  4563       2      0%      0%      0%  S                0  kcryptd_io
  4562       2      0%      0%      0%  S                0  bioset
  4561       2      0%      0%      0%  S                0  kdmflush
  4549       2      0%      0%      0%  S                0  bioset
  4547       2      0%      0%      0%  S                0  dmcrypt_write
  4546       2      0%      0%      0%  S                0  kcryptd
  4545       2      0%      0%      0%  S                0  kcryptd_io
  4544       2      0%      0%      0%  S                0  bioset
  4543       2      0%      0%      0%  S                0  kdmflush
  4419       2      0%      0%      0%  S                0  kworker/1:1H
  4392       2      0%      0%      0%  S                0  kworker/3:1H
  4352       2      0%      0%      0%  S                0  kworker/2:1H
  4300       2      0%      0%      0%  S                0  kworker/5:1H
  4299       2      0%      0%      0%  S                0  kworker/7:1H
  4291       2      0%      0%      0%  S                0  kworker/0:2
  4281       2      0%      0%      0%  S                0  kworker/4:1H
  4268       2      0%      0%      0%  S                0  kworker/6:2
  4265       2      0%      0%      0%  S                0  kworker/0:1H
  4244       2      0%      0%      0%  S                0  kworker/6:1H
  4177       2      0%      0%      0%  S                0  kworker/1:1
  4163       2      0%      0%      0%  S                0  kworker/4:2
  4157       2      0%      0%      0%  S                0  bioset
  4134       2      0%      0%      0%  S                0  bioset
  4129       2      0%      0%      0%  S                0  scsi_tmf_2
  4128       2      0%      0%      0%  S                0  scsi_eh_2
  4124       2      0%      0%      0%  S                0  mpt/0
  4115       2      0%      0%      0%  S                0  mpt_poll_0
  4106       2      0%      0%      0%  S                0  scsi_tmf_1
  4105       2      0%      0%      0%  S                0  scsi_eh_1
  4065       2      0%      0%      0%  S                0  scsi_tmf_0
  4058       2      0%      0%      0%  S                0  scsi_eh_0
  2837    9577      0%      0%      0%  S          4669440  sleep
  2785   16338      0%      0%      0%  S          4677632  sleep
  2442       1      0%      0%      0%  S         35622912  systemd-udevd
  2440       2      0%      0%      0%  S                0  kworker/2:2
  2207       2      0%      0%      0%  S                0  kauditd
  2179       2      0%      0%      0%  S                0  kworker/3:1
  2174       1      0%      0%      0%  S         26828800  systemd-journal
  2170       2      0%      0%      0%  S                0  deferwq
  2163       2      0%      0%      0%  S                0  kworker/7:2
  2152       2      0%      0%      0%  S                0  ipv6_addrconf
  2112       2      0%      0%      0%  S                0  dm_bufio_cache
  2030       2      0%      0%      0%  S                0  bioset
  2029       2      0%      0%      0%  S                0  bioset
  2028       2      0%      0%      0%  S                0  bioset
  2027       2      0%      0%      0%  S                0  bioset
  2026       2      0%      0%      0%  S                0  bioset
  2025       2      0%      0%      0%  S                0  bioset
  2024       2      0%      0%      0%  S                0  bioset
  2023       2      0%      0%      0%  S                0  bioset
  2022       2      0%      0%      0%  S                0  bioset
  2021       2      0%      0%      0%  S                0  bioset
  2020       2      0%      0%      0%  S                0  bioset
  2019       2      0%      0%      0%  S                0  bioset
  2018       2      0%      0%      0%  S                0  bioset
  2017       2      0%      0%      0%  S                0  bioset
  2016       2      0%      0%      0%  S                0  bioset
  2015       2      0%      0%      0%  S                0  bioset
  2012       2      0%      0%      0%  S                0  bioset
  2009       2      0%      0%      0%  S                0  bioset
  2006       2      0%      0%      0%  S                0  bioset
  2003       2      0%      0%      0%  S                0  bioset
  2000       2      0%      0%      0%  S                0  bioset
  1997       2      0%      0%      0%  S                0  bioset
  1994       2      0%      0%      0%  S                0  bioset
  1991       2      0%      0%      0%  S                0  bioset
  1988       2      0%      0%      0%  S                0  bioset
  1985       2      0%      0%      0%  S                0  bioset
  1982       2      0%      0%      0%  S                0  bioset
  1979       2      0%      0%      0%  S                0  bioset
  1976       2      0%      0%      0%  S                0  bioset
  1973       2      0%      0%      0%  S                0  bioset
  1970       2      0%      0%      0%  S                0  bioset
  1967       2      0%      0%      0%  S                0  bioset
  1964       2      0%      0%      0%  S                0  bioset
  1961       2      0%      0%      0%  S                0  bioset
  1958       2      0%      0%      0%  S                0  bioset
  1955       2      0%      0%      0%  S                0  bioset
  1952       2      0%      0%      0%  S                0  bioset
  1949       2      0%      0%      0%  S                0  bioset
  1946       2      0%      0%      0%  S                0  bioset
  1943       2      0%      0%      0%  S                0  bioset
  1940       2      0%      0%      0%  S                0  bioset
  1937       2      0%      0%      0%  S                0  bioset
  1934       2      0%      0%      0%  S                0  bioset
  1931       2      0%      0%      0%  S                0  bioset
  1928       2      0%      0%      0%  S                0  bioset
  1925       2      0%      0%      0%  S                0  bioset
  1922       2      0%      0%      0%  S                0  bioset
  1919       2      0%      0%      0%  S                0  bioset
  1916       2      0%      0%      0%  S                0  bioset
  1913       2      0%      0%      0%  S                0  bioset
  1910       2      0%      0%      0%  S                0  bioset
  1907       2      0%      0%      0%  S                0  bioset
  1904       2      0%      0%      0%  S                0  bioset
  1901       2      0%      0%      0%  S                0  bioset
  1898       2      0%      0%      0%  S                0  bioset
  1895       2      0%      0%      0%  S                0  bioset
  1892       2      0%      0%      0%  S                0  bioset
  1889       2      0%      0%      0%  S                0  bioset
  1886       2      0%      0%      0%  S                0  bioset
  1883       2      0%      0%      0%  S                0  bioset
  1880       2      0%      0%      0%  S                0  bioset
  1877       2      0%      0%      0%  S                0  bioset
  1874       2      0%      0%      0%  S                0  bioset
  1871       2      0%      0%      0%  S                0  bioset
  1868       2      0%      0%      0%  S                0  bioset
  1865       2      0%      0%      0%  S                0  bioset
  1862       2      0%      0%      0%  S                0  bioset
  1859       2      0%      0%      0%  S                0  bioset
  1856       2      0%      0%      0%  S                0  bioset
  1853       2      0%      0%      0%  S                0  bioset
  1850       2      0%      0%      0%  S                0  bioset
  1847       2      0%      0%      0%  S                0  bioset
  1844       2      0%      0%      0%  S                0  bioset
  1841       2      0%      0%      0%  S                0  bioset
  1838       2      0%      0%      0%  S                0  bioset
  1836       2      0%      0%      0%  S                0  kworker/7:1
  1834       2      0%      0%      0%  S                0  bioset
  1831       2      0%      0%      0%  S                0  bioset
  1828       2      0%      0%      0%  S                0  bioset
  1825       2      0%      0%      0%  S                0  bioset
  1822       2      0%      0%      0%  S                0  bioset
  1788       2      0%      0%      0%  S                0  bioset
  1787       2      0%      0%      0%  S                0  bioset
  1786       2      0%      0%      0%  S                0  bioset
  1785       2      0%      0%      0%  S                0  bioset
  1784       2      0%      0%      0%  S                0  bioset
  1783       2      0%      0%      0%  S                0  bioset
  1782       2      0%      0%      0%  S                0  bioset
  1781       2      0%      0%      0%  S                0  bioset
  1780       2      0%      0%      0%  S                0  bioset
  1779       2      0%      0%      0%  S                0  bioset
  1778       2      0%      0%      0%  S                0  bioset
  1777       2      0%      0%      0%  S                0  bioset
  1776       2      0%      0%      0%  S                0  bioset
  1775       2      0%      0%      0%  S                0  bioset
  1774       2      0%      0%      0%  S                0  bioset
  1773       2      0%      0%      0%  S                0  bioset
  1463   18267      0%      0%      0%  S          4677632  sleep
  1239       2      0%      0%      0%  S                0  acpi_thermal_pm
  1229       2      0%      0%      0%  S                0  kworker/5:1
  1088       2      0%      0%      0%  S                0  nfsiod
  1071       2      0%      0%      0%  S                0  fsnotify_mark
   996       2      0%      0%      0%  S                0  vmstat
   995       2      0%      0%      0%  S                0  kswapd0
   952       2      0%      0%      0%  S                0  kworker/4:1
   951       2      0%      0%      0%  S                0  kworker/0:1
   950       2      0%      0%      0%  S                0  rpciod
   854       2      0%      0%      0%  S                0  md
   841       2      0%      0%      0%  S                0  ata_sff
   302       2      0%      0%      0%  S                0  kblockd
   300       2      0%      0%      0%  S                0  bioset
   299       2      0%      0%      0%  S                0  crypto
   297       2      0%      0%      0%  S                0  writeback
   296       2      0%      0%      0%  S                0  khungtaskd
    40       2      0%      0%      0%  S                0  perf
    39       2      0%      0%      0%  S                0  netns
    38       2      0%      0%      0%  S                0  kdevtmpfs
    37       2      0%      0%      0%  S                0  kworker/7:0H
    35       2      0%      0%      0%  S                0  ksoftirqd/7
    34       2      0%      0%      0%  S                0  migration/7
    33       2      0%      0%      0%  S                0  kworker/6:0H
    32       2      0%      0%      0%  S                0  kworker/6:0
    31       2      0%      0%      0%  S                0  ksoftirqd/6
    30       2      0%      0%      0%  S                0  migration/6
    29       2      0%      0%      0%  S                0  kworker/5:0H
    28       2      0%      0%      0%  S                0  kworker/5:0
    27       2      0%      0%      0%  S                0  ksoftirqd/5
    26       2      0%      0%      0%  S                0  migration/5
    25       2      0%      0%      0%  S                0  kworker/4:0H
    23       2      0%      0%      0%  S                0  ksoftirqd/4
    22       2      0%      0%      0%  S                0  migration/4
    21       2      0%      0%      0%  S                0  kworker/3:0H
    20       2      0%      0%      0%  S                0  kworker/3:0
    19       2      0%      0%      0%  S                0  ksoftirqd/3
    18       2      0%      0%      0%  S                0  migration/3
    17       2      0%      0%      0%  S                0  kworker/2:0H
    16       2      0%      0%      0%  S                0  kworker/2:0
    15       2      0%      0%      0%  S                0  ksoftirqd/2
    14       2      0%      0%      0%  S                0  migration/2
    13       2      0%      0%      0%  S                0  kworker/1:0H
    11       2      0%      0%      0%  S                0  ksoftirqd/1
    10       2      0%      0%      0%  S                0  migration/1
     9       2      0%      0%      0%  S                0  migration/0
     8       2      0%      0%      0%  S                0  rcu_bh
     7       2      0%      0%      0%  R                0  rcu_sched
     5       2      0%      0%      0%  S                0  kworker/0:0H
     3       2      0%      0%      0%  S                0  ksoftirqd/0
     2       0      0%      0%      0%  S                0  kthreadd
     1       0      0%      0%      0%  S         40579072  systemd
And:
csr1000v#           show platform hardware qfp active datapath utilization summary
Input:     Total (pps)        60721        54738        55714         8693
                 (bps)    657633304    587731152    582688120     87551096
Output:    Total (pps)        60687        54731        55715         8694
                 (bps)    632837712    566044688    561997504     84602048
Processing: Load (pct)           99           92           91           14
post the full running configuration of your router...
Hello. Config of CSR in attach. Crypto keys and some acl with public addresses were removed.
Thank you!
With best regards, Sergey.
you have a lot of ACL logging configured. Everything that is logged gets punted to the CPU and is process switched, that could explain the high CPU. I have marked all the 'log' keywords (in bold) in your configuration. try and remove these and check if that makes a difference. Also, the IP SLA tracking seems redundant, since there is nothing configured that can be tracked, so you might want to remove these lines as well...
version 16.9
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform console virtual
hostname csr1000v
boot-start-marker
boot-end-marker
logging buffered 256000
logging console critical
enable secret <secret>
aaa new-model
aaa authentication login default local
aaa authentication login CONSOLE local
aaa authorization console
aaa session-id common
clock timezone
no ip domain lookup
ip admission watch-list expiry-time 0
subscriber templating
object-group network hub.spoke.int
<hidden>
redundancy
--> no track 10 ip sla 10 reachability
delay down 60 up 60
--> no track 20 ip sla 20 reachability
delay down 60 up 60
crypto isakmp policy 10
encr 3des
authentication pre-share
group 5
lifetime 3600
crypto isakmp key <key> address 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 15 periodic
crypto ipsec transform-set DMVPN-TS esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set DMVPN-MTRANS esp-3des esp-sha-hmac
mode transport
mode transport
crypto ipsec transform-set GRE-AES-TEST esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile AES-TEST
set transform-set GRE-AES-TEST
set pfs group2
crypto ipsec profile DMVPN-PROFILE
set transform-set DMVPN-TS
set pfs group5
crypto ipsec profile DMVPN-TUN
set pfs group5
crypto ipsec profile DMVPN-TR
set transform-set DMVPN-MTRANS
set pfs group5
interface Tunnel35
description [BKP] DMVPN
bandwidth 10000
ip address 10.35.101.229 255.255.252.0
no ip redirects
ip mtu 1396
ip nhrp authentication VLx18
ip nhrp network-id 35
ip nhrp nhs 10.35.100.1 nbma 9.9.9.9 multicast
delay 1100
tunnel source GigabitEthernet4
tunnel key 35
tunnel protection ipsec profile DMVPN-TR shared
interface Tunnel36
description [PRI] DMVPN
bandwidth 10000
ip address 10.36.101.229 255.255.252.0
no ip redirects
ip mtu 1396
ip nhrp network-id 36
ip nhrp nhs 10.36.100.1 nbma 11.11.11.11 multicast
delay 1000
tunnel key 36
interface Tunnel188
description [PRI]
bandwidth 10000
ip address 10.188.100.229 255.255.252.0
no ip redirects
ip mtu 1396
ip nhrp authentication 18dm
ip nhrp map 10.188.100.1 12.12.12.12
ip nhrp map multicast 12.12.12.12
ip nhrp network-id 188
ip nhrp nhs 10.188.100.1
delay 1000
tunnel key 188
ip virtual-reassembly
interface Tunnel189
bandwidth 10000
ip address 10.189.200.229 255.255.252.0
no ip redirects
ip mtu 1396
ip nhrp authentication x18dm
ip nhrp map 10.189.200.1 13.13.13.13
ip nhrp map multicast 13.13.13.13
ip nhrp network-id 189
ip nhrp nhs 10.189.200.1
delay 1050
shutdown
tunnel key 189
interface GigabitEthernet2
description Link Servers network [172.17.16.1]
ip address 172.17.16.1 255.255.255.0
ip nat inside
negotiation auto
interface GigabitEthernet3
ip address 172.17.17.1 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet4
description -- ISP-1 Optical, 1000 Mbps --
ip address 4.4.4.2 255.255.255.252
no ip redirects
no ip proxy-arp
ip nat outside
ip access-group 111 in
ip access-group 121 out
ip tcp adjust-mss 1360
load-interval 30
negotiation auto
router eigrp 1
network 10.188.0.0 0.0.255.255
network 10.189.0.0 0.0.255.255
network 172.17.16.0 0.0.0.255
offset-list TmpWorseRoute in 300000
passive-interface default
no passive-interface Tunnel188
no passive-interface Tunnel189
eigrp stub connected summary
router eigrp 3
network 10.35.0.0 0.0.255.255
network 10.36.0.0 0.0.255.255
network 172.17.17.0 0.0.0.255
no passive-interface Tunnel36
no passive-interface Tunnel35
router eigrp 81
network 10.32.81.0 0.0.0.3
ip nat inside source route-map MATCH-ISP1-NAT interface GigabitEthernet4 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 4.4.4.1 100
ip access-list standard TmpWorseRoute
permit 172.20.20.0 0.0.0.255
ip access-list standard acl-mgmt
permit <our mgmt networks>
--> no deny any log
ip access-list standard acl-snmp
permit 172.21.79.142
permit 172.21.79.80
permit 172.21.1.101
--> no deny any log
ip access-list standard no-redisrt-eigrp
permit 172.18.0.0 0.0.255.255
permit 172.21.0.0 0.0.255.255
deny any
<some DMZ access-lists>
logging trap notifications
logging host 172.21.79.142
access-list 105 deny ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
access-list 105 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 105 deny ip 172.16.0.0 0.15.255.255 172.16.0.0 0.15.255.255
access-list 105 permit ip host 172.17.16.13 host <our public host>
access-list 105 permit ip host 172.17.16.10 host <our public host>
access-list 105 permit ip host 172.17.16.11 host <our public host>
access-list 105 deny ip any any
access-list 111 permit icmp any any
access-list 111 permit udp any eq isakmp any eq isakmp
access-list 111 permit udp any eq non500-isakmp any eq non500-isakmp
access-list 111 permit udp any eq ntp any eq ntp
access-list 111 permit tcp any any established
access-list 111 permit ip host <our public host> any
access-list 111 permit ip <our public host> any
access-list 111 permit ip object-group hub.spoke.int any
access-list 111 permit gre host <our public host> host <our ext ip>
access-list 111 deny ip 10.0.0.0 0.255.255.255 any log
access-list 111 deny ip 172.16.0.0 0.15.255.255 any log
access-list 111 deny ip 192.168.0.0 0.0.255.255 any log
access-list 111 deny udp any eq ntp any log
access-list 111 deny ip any host 255.255.255.255
access-list 111 deny ip any any
access-list 112 permit ip host <our public host> any
access-list 121 permit icmp any any
access-list 121 deny ip host 0.0.0.0 any log
access-list 121 deny ip 127.0.0.0 0.255.255.255 any log
access-list 121 deny ip 10.0.0.0 0.255.255.255 any log
access-list 121 deny ip 172.16.0.0 0.15.255.255 host 172.30.165.255
access-list 121 deny ip 172.16.0.0 0.15.255.255 any log
access-list 121 deny ip 192.168.0.0 0.0.255.255 any log
access-list 121 deny ip 169.254.0.0 0.0.255.255 any log
access-list 121 deny ip 192.0.2.0 0.0.0.255 any log
access-list 121 deny ip 224.0.0.0 15.255.255.255 any log
access-list 121 deny ip 240.0.0.0 15.255.255.255 any log
access-list 121 permit ip any any
route-map MATCH-ISP1-NAT permit 10
match ip address 105
snmp-server community <our_ro_community> RO acl-snmp
snmp ifmib ifindex persist
control-plane
line con 0
exec-timeout 5 0
logging synchronous
login authentication CONSOLE
stopbits 1
line vty 0
access-class acl-mgmt in
exec-timeout 0 0
transport input all
line vty 1 4
exec-timeout 0 0
length 0
transport input all
line vty 5 15
exec-timeout 0 0
length 0
transport input all
--> no ntp logging
ntp server 172.21.66.11
ntp server 172.21.65.11
Thank you for your reply, but I think this is no right way: CPU usage is so high when there is traffic in tunnels with crypto, and is near zero when there is no traffic in tunnels. Fortunately no one floods our router with prohibitted traffic ;)
Thank you
With best regards,
Sergey Kanovskiy.
looking at your original post again:
--> Our problem is low network throughput with DMVPN + IPSEC tunnels. I didn't saw network speed more than 650 mbit\sec and the CPU usage in that situation is full:
--> Network speed become ~750 mbit/sec if I remove crypto and send packets with 1350 bytes length.
You are talking about a 13 percent drop in throughput for IPSec traffic. That by itself is pretty much to be expected. Are the users experiencing any problems with delays or drops ?
The only other thing I noticed is that one of your tunnels has 'virtual-reassembly' enabled, you might want to try and turn that off...
interface Tunnel188
description [PRI]
bandwidth 10000
no ip redirects
ip mtu 1396
delay 1000
tunnel key 188
--> no ip virtual-reassembly
All of  applications are using tcp protocol and have no loose of packets, but delays increases by 3-4 msec when throughput reaches 650-670 Mbit/sec.
how do you notice these delays ? 3 or 4 msecs would only ne noticeable in real time traffic such as voice and video, I guess. You could consider implementing some sort of QoS to prioritize sensitive traffic, is that an option ?
Joseph W. Doherty
If your virtual router is a tunnel end-point, encryption processing will likely hit the CPU harder than no encryption and further if your tunnel needs to fragment packets, that too may cause increased CPU consumption.
Thank you for your reply.
What does this process do? "ucode_pkt_PPE0"
Sorry, that I don't know.
alex6
Hi Sergey!
Have you found a solution?
Aleksandr Roldugin
Cabal
Hello, did you foun any sollution for this problem?
Thank you
Jiri
