CSR 1000v software upgrade path??
kay.kang
I'm planning to upgrade our operating CSR 1000v software.
The current version is 16.6.3 and plan to upgrade 17.3.5.
I am wondering if there is any condition about upgrade path or it's possible to upgrade straight from the current version.
Mark Elsen
            - Check Release Notes of the targeted version , then look for upgrade and installation notes.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
braids
I'm trying to sort change out to upgrade CSR 1000v from 16.06.01 to 16.12.05
There are 2 documents that contradict each other which is the correct document to use:
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1[…]ration_Guide/b_CSR1000v_Configuration_Guide_chapter_01001.html
or
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/aws/b_csraws/m_upgrading-ios-xe-image-on-aws.html
The CSR's are in AWS
