02-04-2016 07:34 AM - edited 03-05-2019 03:16 AM
Hi All,
I thought the CSR1000v was available for use so that you could use it in a lab (e.g. CCIE prep) and that there was just a limit on the amount of throughput on the instance (2Mb/s) without the license. I work for a SP and have several contracts under my account but can't download a copy of it although various older blogs seem to boast it was "free to use".
Is anyone aware of the policies surrounding this? Seems cisco does not allow you to download unless you purchase now.
Brian
Solved! Go to Solution.
02-05-2016 01:15 AM
If you have a quad core i7 and 12GB of RAM in your computer then consider Cisco VIRL.
02-05-2016 01:14 AM
This PDF has links to a download and it seems to let you download it.
Download link:
02-05-2016 05:10 AM
Thanks!
02-05-2016 11:36 AM
If you think I helped it would be great if you could rate the post and mark it as correct. :-)
02-05-2016 01:15 AM
