CSR1000v performance
CSCO11879898
Dear Community,
We are using the Cisco Cloud Services Router (CSR) 1000V - AX Pkg. Max Performance in our AWS environment.
Actually we deployed the EC2 type c4.2xlarge. Do we have to consider the following limits for the throughput even if we don’t use all AX features ?
We only using VRF lite + GRE and no IPSEC.
AX
t2.medium 250Mbps
m3.medium 250Mbps
c4.large 500Mbps
c4.xlarge 1000Mbps
C3.2xlarge 1000Mbps
c4.2xlarge 2500Mbps
c4.4xlarge 5000Mbps
C4.8xlarge 5000Mbps
According to the following links (https://www.cisco.com/c/en/us/products/collateral/routers/cloud-services-router-1000v-series/data_sheet-c78-733443.html) :
We can achieve 10 Gig with IPbase package. Is this also available for AX package even if we don’t use IPSEC ?
The throughput limitation is it related to the type of package or to the features used on the CSRs ?
0 Replies 0
