CSR1000v Throughput Licensing: Input, Output or Both?
ballbag
Hello all,
I'm trying to quantify the overall utilization of a CSR1000v router to ensure that we're using the correct license level.
Here's an example of the utilization:
router#sho platform hardware qfp active datapath utilization summary
  CPP 0:                     5 secs        1 min        5 min       60 min
Input:     Total (pps)         9280         7642         7377         7205
                 (bps)     42033048     34816632     33352488     31469816
Output:    Total (pps)         9262         7622         7357         7184
                 (bps)     42053528     34892312     33428480     31547184
Processing: Load (pct)            2            2            2            3
Looking at the last 5 seconds, should you license for the input/output (i.e. around 40Mbps), or both added together (around 80Mbps)?
Thanks! :)
balaji.bandi
if you have purchased 50MB License, it means you have maximum throughput limited to 50 MB.
Bare in mind if you going higher level more than 1GB, you need to consider looking your vNIC capacity also.
BB
