CSR1000v WEBUi not reponding!
Menon
Greetings,
I've deployed a new Cisco CSRr1000v(Cisco IOS XE Software, Version 17.03.04a) VM on Proxmox and tried to access the web interface, but it's taking a long time to load. It had the same loading issue when I did the same deployment before, however, it has resolved after a few minutes of loading :).
I am getting logged in, but cannot do anything because the loading process is taking so long, also there is no admin panel option there. Does this have to do with the resources I allocated to the VM? - Can the WEB UI be checked or troubleshot via a terminal?. I would greatly appreciate your suggestion.
Punk_jr
marce1000
             - Is the 'proxmos' supported a valid virtual and or hypervisor solution , check requirements here :
 https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_00.html#con_1094088
 M.
