Hello All
trying to lab mp-bgp vxlan evpn with CSR1Kv platforms only on eve-ng@GCP. problem happens on very 1st step of populating MP-BGP L2VPN EVPN RIB with type 2 routes learned on attached VNIs (sho bgp l2 evpn shows nothing & debug on l2vpn evpn RIB activity is empty). BDIs are pretty populated with MACs of atatched hosts. Could it be because NVE1 doesnt allow addition of local VNIs when host-reachability bgp is configured or by other reason? any help appreciated
hostname PE1CSR1Kv1641
vrf definition vrf-Tenant1
rd 65000:1
address-family ipv4
route-target export 65000:1 stitching
route-target import 65000:1 stitching
exit-address-family
ip multicast-routing distributed
bridge-domain 10
member vni 5000
member GigabitEthernet3 service-instance 1
member GigabitEthernet4 service-instance 1
member GigabitEthernet4 service-instance 3
bridge-domain 20
member vni 5001
member GigabitEthernet3 service-instance 2
member GigabitEthernet4 service-instance 2
bridge-domain 1000
member vni 10000
member GigabitEthernet3 service-instance 1000
bridge irb
interface Loopback0
ip address 10.0.10.1 255.255.255.255
ip pim sparse-mode
ip router isis POD1
interface GigabitEthernet1
ip unnumbered Loopback0
no ip redirects
no ip proxy-arp
ip pim sparse-mode
ip router isis POD1
negotiation auto
medium p2p
arp timeout 60
isis network point-to-point
interface GigabitEthernet2
no ip redirects
no ip proxy-arp
ip pim sparse-mode
ip router isis POD1
negotiation auto
medium p2p
arp timeout 60
interface GigabitEthernet3
description CE3
no ip address
speed 1000
no negotiation auto
service instance 1 ethernet
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
service instance 2 ethernet
encapsulation dot1q 20
service instance 1000 ethernet
encapsulation dot1q 1000
snmp ifindex persist
interface GigabitEthernet4
description CE4
no ip address
speed 1000
no negotiation auto
encapsulation dot1q 40
service instance 3 ethernet
encapsulation dot1q 15
interface BDI10
vrf forwarding vrf-Tenant1
ip address 10.10.10.1 255.255.255.0
interface BDI1000
interface nve1
description L3-VNI
no ip address
source-interface Loopback0
host-reachability protocol bgp
member vni 10000 vrf vrf-Tenant1
router isis POD1
net 49.0000.0000.0000.0001.00
is-type level-2-only
router-id Loopback0
log-adjacency-changes
router bgp 65000
bgp router-id 10.0.10.1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 10.0.10.2 remote-as 65000
neighbor 10.0.10.2 update-source Loopback0
neighbor 10.0.10.3 remote-as 65000
neighbor 10.0.10.3 update-source Loopback0
address-family l2vpn evpn
neighbor 10.0.10.2 activate
neighbor 10.0.10.2 send-community both
neighbor 10.0.10.2 soft-reconfiguration inbound
neighbor 10.0.10.3 activate
neighbor 10.0.10.3 send-community both
neighbor 10.0.10.3 soft-reconfiguration inbound
exit-address-family
ip pim bidir-enable
ip pim rp-address 10.1.1.1 bidir
