Custom Queuing - Byte-Count vs Packet Limit in a Queue
kfarrington
Level 3
Level 3
Good morning all. I hope everyone is very well.
I have just configured the below, and it shows that I can have, both byte-count, and a packet-count for Queue 5.
What takes precedence for the scheduler to move onto the next queue?
Kind regards,
Ken
Dual3(config-subif)#queue-list 11 protocol ip 1 list 15
Dual3(config)#queue-list 11 protocol ip 2 tcp 8080
Dual3(config)#queue-list 11 protocol ip 3 udp netbios-dgm
Dual3(config)#queue-list 11 protocol ip 4 tcp 23
Dual3(config)#queue-list 11 default 5
Dual3(config)#queue-list 11 queue 1 byte-count 5000
Dual3(config)#queue-list 11 queue 2 byte-count 1250
Dual3(config)#queue-list 11 queue 4 byte-count 4000
Dual3(config)#queue-list 11 queue 5 byte-count 2000
Dual3(config)#queue-list 11 queue 5 limit 40
Dual3(config)#access-list 15 permit 155.195.0.0 0.0.255.255
Dual3(config)#interface e0/1
Dual3(config-if)# custom-queue-list 11
Dual3(config-if)#
Dual3(config-if)#^Z
Dual3#show queueing custom
*May 10 18:59:57 BST: %SYS-5-CONFIG_I: Configured from console by console
Current custom queue configuration:
List Queue Args
11 5 default
11 1 protocol ip list 15
11 2 protocol ip tcp port 8080
11 3 protocol ip udp port netbios-dgm
11 4 protocol ip tcp port telnet
11 1 byte-count 5000
11 2 byte-count 1250
11 4 byte-count 4000
11 5 byte-count 2000 limit 40
Dual3#
Ken
You can define either or both of byte count or packet count to define a threshold for custom queuing at which it should move on to the next queue. It is my understanding that when you have both byte count and packet count configured the first one to get satisfied will cause it to move on to the next queue.
If you do not define which queue is the default custom queuing will treat queue 1 as the default.
Rick
Rick
kfarrington
Level 3
Level 3
Also, What happens if you do not speficify a default queue within custom queueing?
Priority queueing just whackes it in the normal queue does it not? Custom queuing? just a thought :)
Below I remove it.
Dual3#sh queueing custom
List Queue Args
11 5 default
Dual3#
Dual3#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Dual3(config)#no queue-list 11 protocol ip 1 list 15
Dual3(config)#no queue-list 11 protocol ip 2 tcp 8080
Dual3(config)#no queue-list 11 protocol ip 3 udp netbios-dgm
Dual3(config)#no queue-list 11 protocol ip 4 tcp telnet
Dual3(config)#no queue-list 11 default 5
Dual3(config)#no queue-list 11 queue 1 byte-count 5000
Dual3(config)#no queue-list 11 queue 2 byte-count 1250
Dual3(config)#no queue-list 11 queue 4 byte-count 4000
Dual3(config)#no queue-list 11 queue 5 byte-count 2000 limit 40
Dual3(config)#
Dual3(config)#
Dual3(config)#^Z
*May 10 21:55:38 BST: %SYS-5-CONFIG_I: Configured from console by console
List Queue Args
Dual3#
List Queue Args
Dual3#conf t
Dual3(config)#queue-list 11 protocol ip 1 list 15
Dual3(config)#queue-list 11 protocol ip 4 tcp telnet
Dual3(config)#queue-list 11 queue 5 byte-count 2000 limit 40
Dual3(config)#
Dual3(config)#^Z
*May 10 21:56:12 BST: %SYS-5-CONFIG_I: Configured from
List Queue Args
Dual3#
Dual3#
Ken
Rick
Rick
Brilliant!
Many thx fella, Im sure I owe you beers now :)
