CWM SNMP Agent: Modifying ATM-Fr middle end point parameters?
jbocanegra
I've been unsuccessfully trying to modify parameters for svConnMiddlEndPt on a ATM-FR connection between a BPX 8620 and a MGX 8230. Syntax seems to be correct, for I can thus modify parameters on the ATM 'final' end point:
bash$ snmpset -p 8161 localhost private atmEndPointSCRZeroPlus1.6.65.66.73.45.66.49.0.1.1.1.1 i 50
Error in packet.
Reason: (genError) A general failure occured
Failed object: enterprises.stratacom.svplus.serviceGroup.connGroup.atmEndPointTable.atmEndPointEntry.atmEndPointSCRZeroPlus1."ABI-B1"."".1.1.1.1
bash$ snmpget -p 8161 localhost public svCmpaErrorLastDesc.0
enterprises.stratacom.svplus.serviceGroup.connGroup.svCmpaErrorLastDesc.0 = "[11/24/2005 11:04:48] Port [1.0.1] not found"
Nevertheless, I can modify the same parameters on the end point:
bash$ snmpset -p 8161 localhost private atmEndPointSCRZeroPlus1.6.65.66.73.45.66.49.0.1.3.201.201 i 50
enterprises.stratacom.svplus.serviceGroup.connGroup.atmEndPointTable.atmEndPointEntry.atmEndPointSCRZeroPlus1."ABI-B1"."".1.3.201.201 = 50
Any help will be truly appreciated!
Juan Miguel
mnewnam05
I'm not familiar with these models, but if an ATM card is used it must be seated before MIBs are populated.
