Data Encryption over leased lines
sriganesh14
Hi Experts,
  I have Leased lines & ISDN between Data Center to branches. Total 45 branches. I need to encryprt data traffic for all 45 branches
  How can i do this in cisco router.  Kindly reply
  Thanks in advance.
Ganesh.
Leo Laohoo
Hi Leo,
Thanks for ur reply.
  Above example is using internet cloud, but i'm having point to point Leased lines using serial & BRI interfaces.
I don't have tunnel interface.
And also one more question how many crypto map sequence number can be supported by cisco 3925 router(Central site).
If i created 50 sequence no is there any memory or processor issue will be raised?
50 GRE tunnels is nothing.  What I'd like to know is what is the total bandwidth to your head office and whether or not your router has built-in Encryption module.
Collin Clark
Personally I would use GETVPN. It was designed for encrpyting over MPLS, but it works equally well over point-to-point circuits. It scales very well, I've had 30+ sites.
http://www.cisco.com/c/en/us/products/security/group-encrypted-transport-vpn/index.html
