datacenter interconnection doubt
gpangallo
I need to interconnect two datacenters through a IP/MPLS network. I need to exchange the DB information between them and I see it's possible to use the EoMPLS technology for.
The problem is due to the fact that I don't have the SPA module with SIP 400 in Cat6509 as advised by Cisco but only the SUP720 10GE.
The question is: Could I implement the EoMPLS using only the SUP 720 10GE VSS?
Thank you in advance for your help.
Regards.
Giuseppe
Giuseppe Larosa
Hello Giuseppe,
we have recently implemented an EoMPLS using tengiga ports of a WS-X6708-10GE.
My understanding is that a SIP linecard or ES linecards are needed if you plan to use the xconnect under SVI interface.
if you want to use xconnect under a physical port or a vlan subinterface you should be fine.
Hope to help
Giuseppe
