Datacenter Technologies 2020
bhalla.himanshu
Hello Everyone,
Currently we are having Nexus 7706 , Nexus 1k and ASA firewall with in our datacenter to support ECOMMERCE business accross 50 countries and  I would need your help to know about new technologies to accommodate traffic load and upcoming underlined technologies on 2020 when we were introduced in 100 +  other countries what parameter should I consider while designing the future network.
Thanks!
Himanshu Bhalla
jkilleda
Level 3
Level 3
Hello  Himanshu,
Data center Technologies 2020
Before implementing any device check it's EOL so that you can be updated and think exactly where you can best put the device in production , so that if in future you have to migrate the device then the downtime shouldn't affect much.
Keep your network simple yet updated with the latest technologies used.
Before installing the device , make sure you double check the hardware of any device , which will help the smooth flow of the network.
