Branch Connectivity Design
edwincharles
Hello Team,
Need help with designing the Branch connectivity as attached.
Can anyone provide a low budget solution for the above and what is required. like BoM
10 Replies 10
Deepak Kumar
I am not sure, what is network utilization in peak time. I suggest go with Cisco ASA firewall and anyconnect VPN solutions.
Head Office:
Cisco ASA 5505
Cisco 3850/2960 Switch (24 or 48 ports as per your requirement, But I suggest for 48 Port).
You can configure VPN solution on the firewall so branch users can access application server securely.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks deepak,
Do we require static ip on headoffice, or normal DSL internet with dhcp public ip will do for VPN
There is no need for fixed IP, you can use it with dynamic IP with DynDNS address.
DynDNS is available freeware and paid both.
Deepak Kumar
Deepak Kumar,
Hello Deepak,
can you confirm on the below BoM
Part Number Description
ASA5506-K9 ASA 5506-X with FirePOWER services, 8GE, AC, 3DES/AES
CON-SSSNT-ASA5506K SOLN SUPP 8X5XNBD ASA 5506-X with FirePOWER services 8GE A
CAB-ACU AC Power Cord (UK), C13, BS 1363, 2.5m
SF-ASA-K-9.8.2-K8 Cisco ASA 9.8.2 Software image for ASA 5506/5508/5516 series
SF-ASA-FP6.2.2-K9 Cisco FirePOWER Software v6.2.2 for ASA 5500-X
ASA5506-CTRL-LIC Cisco ASA5506 Control License
AC-VPNO-25 Cisco AnyConnect VPN Only, 25 Simultaneous, ASA Opt (Paper)
CON-ECMUS-ACVA25 SOLN SUPP SWSS Cisco AnyConnect VPN Only, 25 Simultaneous, A
ASA5506-SSD ASA 5506-X SSD
ASA5500-ENCR-K9 ASA 5500 Strong Encryption License (3DES/AES)
ASA5506-PWR-AC ASA 5506-X Power Adaptor
WS-C2960X-48TS-L Catalyst 2960-X 48 GigE, 4 x 1G SFP, LAN Base
CON-SSSNT-WSC248TS SOLN SUPP 8X5XNBD Catalyst 2960-X 48 GigE 4 x 1G SFP LAN B
Everything is looking good. Please verify about a licence "ASA5500-ENCR-K9" is freeware or paid with asa?
I hope so in the device description you mention that this encryption is includ in the asa.
Deepak Kumar
Deepak Kumar,
ASA5500-ENCR-K9
its price is zero so its included with ASA
is this license for 25 concurrent anyconnect connection using anyconnect client on desktop
Yes, only 25 users can connect vpn at a time.
Deepak Kumar
Deepak Kumar,
Hello ,
does the attached has anyconnect client license
Some anyconnect licenses are showing disabled, first make it enable.
Deepak Kumar
Deepak Kumar,
does the ANYCONNECT PREMIUM PEERS  2 supports 2 users to connect to VPN
