DCD=up DSR=down DTR=up RTS=up CTS=up but pinging
kbchoudhury
at remote-end router WAN interface it shows DCD=up DSR=down DTR=up RTS=up CTS=up and local-end router is fine with no error and everything is up and ping over this WAN connection to the remote network then what can be the cause of the remote-end DSR=down ?
paolo bevilacqua
Check the the device connected to serial. Router is merely reporting the status of a pin.
