DDNS - CISCO IOS ROUTERS
veltech
Hi All,
We have been asked by one of our customers to configure DDNS service on their 1841 with NOIP.com. This is not something we have done very often as most customers who run a DDNS service tend to use a client or server on the inside network. This customer wants the 1841 to take care of DDNS updates for their dynamic IP address changes. I have reviewed the Cisco documentation but does anyone have a simple config we could use to get this running??
As always all help greatly appreciated.
Lei Tian
Check configure example from:
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dns/configuration/15-1mt/Dynamic_DNS_Support_for_Cisco_IOS_Software.html
HTH,
Lei Tian
ip ddns update method mytest
ddns
 http
!Before entering the question mark (?) character in the add http CLI, press the control (Ctrl) key and the v key together on your keyboard. This will allow you to enter the ? without the software interpreting the ? as a help query.
 add http://test:test@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
 interval maximum 1 0 0 0
 exit
interface ether1
 ip ddns update hostname abc.dyndns.org
 ip ddns update mytest
