debug ip ospf * is not working
ajf303
when i am typing debug ip ospf * (events, hello, etc) in cisco router, I am getting output nothing.
It has two neighbor established and working on the same router.
what could be the problem....?
thx.
Franco
Sindhu_kumar
If you telnet or ssh any router at that time you won’t see any console message and debug message  by default in VTY. If you want to see that terminal message at that time we need to enable the below command.
R1#terminal monitor
If you like to disable it try the below command
R1#terminal no monitor
By default router sends all log message to its console port.
you can enable that by using
conf t
logging console
To verify use sh log
Sindhu_kumar
R1#terminal monitor
conf t
logging console
Thanks SIndhu..
