Debug Output
tahseen12
I am using debug ip packet command with ACL on 7600 router but no output seen.
Is debug command with acl has issue?
Farrukh Haroon
Are you telnetting into the router?
If so don't forget the 'terminal monitor' command.
Also 'logging monitor 7' should be configured.
If you connected through the console, 'logging console 7' should be there.
Also are other debugs working/displaying?
Farrukh
