debug q931 : error message....
azmirccnp
Level 2
Level 2
Can anyone tell me what this error message indicate?
**ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 17 call id 0x274C
I've counter a problem with my VOIP where users can't hear the voice clearly, then I use the 'debug q931' command at the router connected to PABX thru PRI. The error above popup along with other normal message. Can anyone help me?
Thanks.
paolo bevilacqua
Hi Azmir,
this error message is normal. I have it on all the ISDN installations and the calls are normal.
Hopefully cisco will eliminate the spurious message sometime.
Are your E1 controllers clean of slips ? Do "show controllers E1".
How to know its clean fr slips?
Here is my show controller e1 outcome :-
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060623, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (574 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Thanks.
E1 is fine. Any more detail on the voice quality problem to help pinpoint the cause ?
vinay_verma80
Level 3
Level 3
hi
exatly what is the problem with the voice call
can both part can't hear each other or one party can here but other can not
also have u deployed QOS , try only one call( ie ur router should be having only one call )
what is the voice quality
the error u have specified will not have any quality problem , it will be having inpact on call setup as the is not B channel avaliable
regards
