04-13-2006 08:49 AM - edited 03-03-2019 12:24 PM
I have a customer the runs DECnet. Is there a way to encapsulate DECnet over IP so that it will run over their MPLS network as well as their VPN backup network?
Solved! Go to Solution.
04-13-2006 09:28 AM
DECnet can be encapsulated in IP using a GRE tunnel between the two routers needing DECnet connectivity.
This only requires to configure DECnet on the tunnel interface.
Hope this helps,
04-13-2006 09:28 AM
Hope this helps,
