access list
rehan_uet
I dont want to have internet accces for my network, but there are some machines on which i need to have interner access only for windows auto updates and antivirus McAfee auto updates.
Can I limit this access through an access list on a router, if yes then how?
pkhatri
Level 11
Level 11
Yes, you can. I would probably configure an inbound access-list on the router interface towards your LAN which allows those IP addresses to get out to the Internet but blocks everything else.
Post more details/router configs if you want more details...
Pls do remember to rate posts.
Paresh
Paresh
Paresh
config is attached, currently we have only GRE tunnel configured on it once we have access list i will config nat for internet access. I would appriciate if you could suggest a access list with particular port numbers for windows update and McAfee updates rest of the traffic should be denied.
router#sh run
Building configuration...
Current configuration : 1621 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router
interface Tunnel0
ip address 10.34.0.2 255.255.255.252
tunnel source x.x.x.194
tunnel destination y.y.y.115
interface FastEthernet0/0
ip address x.x.x.194 255.255.255.224
speed 100
full-duplex
interface FastEthernet1/0
ip address 10.10.118.1 255.255.0.0
speed 100
full-duplex
interface Serial1/0
no ip address
shutdown
clockrate 2000000
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/1
no ip address
shutdown
clockrate 2000000
router rip
version 2
passive-interface default
no passive-interface Tunnel0
network 1.0.0.0
network 10.0.0.0
neighbor y.y.y.115
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.193
ip http server
dial-peer cor custom
line con 0
password xxxx
login
speed 115200
line aux 0
line vty 0 4
password xxxxx
login
end
router#
Hi Paresh,
I've been pondering on this issue some time ago.
In his case, he wants to limit Internet access to a group of machines, for Windows Updates and McAfee Antivirus Updates only.
Because the IP addresses of these servers may change though the FQDN don't, how do we go about configuring the ACL?
access-list 100 permit tcp host any eq ?
Please advise.
Thank you.
B.Rgds,
Lim TS
you could use NBAR to match HTTP URLs assuming the McAfee updates use HTTP. Microsoft updates should be no problem.
It could look like this (untested though, as I have no router available right now):
class-map match-all MS
match ip address 100
match protocol http url "*.microsoft.com"
class-map match-all McAfee
match protocol http url "*.mcafee.com"
class-map match-any restrict
match not class MS
match not class McAfee
policy-map MyMap
class MS
class McAfee
class restrict
drop
interface Ethernet0/0
service-policy input MyMap
access-list 100 permit ip host any
Hope this helps! Please rate all posts.
Regards, Martin
