Default BGP Route is not getting Redistribute into EIGRP...
Hi All,
I am in a situation while Redistributing the Default Route from the BGP (External) to EIGRP??? But, I am not getting the default route in the eigrp domain...
Let me know that what i am missing here...
Output,
R1# sh ip route | in 0.0.0.0/0
B* 0.0.0.0/0 [20/0] via xx.xx.xx.xx, 00:11:44
R1#
RTR02B2-2454AD1#sh run | b r e
router eigrp 100
redistribute static
redistribute bgp 65089
network 10.13.2.2 0.0.0.0
network *.*.*.* *.*.*.*
no auto-summary
Looking for quick response...
Mubasher
rais
Level 7
Level 7
You must provide metrics for EIGRP for this route to be redistributed.
Thanks.
5 Replies 5
rais
Level 7
Level 7
Thanks.
Thanks Man, it worked with
router eigrp 100
redistribute bgp 65089 metric 1 1 1 1 1
Rate 5
peterlmyers
Hi Mubasher,
By default you cannot redistribute from BGP into IGP protocols. You need to add the command 'bgp redistribute-internal' under router bgp to make this work.
Cheers
This is true for routes learned via iBGP only. This appears to be the case in question.
A route-map restricting only default route to be redistributed would also help.
Thanks.
carlos.morillo
Assuming the following:
-These router are connected to a WAN
-RTR02 is the router closer to the default gateway.
-R1 is a far-end router with a local EIGRP network.
If that is the case RTR02 is correctly redistributing 0.0.0.0
at the R1 site; for that route to be re-distributed to the LAN you routing configuration in R1 sould look like:
router eigrp 100
redistribute bgp 65abc
network 10.0.0.0
default-metric 44210 20 255 255 4470
no auto-summary
router bgp 65abc
no synchronization
bgp log-neighbor-changes
redistribute eigrp 100
neighbor aaa.bbb.ccc.ddd remote-as xyz
no auto-summary
That metric is a default for a DS/3; for a T1 will be a bit diferent.
Carlos
