03-15-2012 08:17 AM - edited 03-04-2019 03:40 PM
Hi All,
Below is the network diagram. The users PC (R7) gw is the HSRP IP address 10.1.2.1. But when do tracert to the 172.16.16.1, it shows first hop as 10.1.2.2.
Network diagram:
Output:
R7#traceroute 172.16.16.1
Tracing the route to 172.16.16.1
1 10.1.2.2 92 msec 172 msec 176 msec -------------------->R5 is primary router of the HSRP
2 192.168.1.2 264 msec 184 msec 104 msec
3 172.16.16.1 96 msec * 80 msec
R7#wr
Building configuration...
[OK]
1 10.1.2.3 68 msec 36 msec 16 msec ------>shutdown the R5
2 * *
192.168.1.1 48 msec
3 172.16.16.1 76 msec * 72 msec
R7#sh
R7#show ip
R7#show ip ro
R7#show ip route
R7#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.1.2.1 to network 0.0.0.0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.2.0 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 10.1.2.1
R7#
Please let me know why the output shows the first hop as the physical IP and not the HSRP IP addresss. Is this the default behavior?
Please explain.
Ravindra K
Solved! Go to Solution.
03-15-2012 09:45 AM
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800a9679.shtml#tr
Please rate...
03-15-2012 08:38 AM
This is normal. The physical address responds when doing a traceroute.
HTH,
John
03-15-2012 09:26 AM
ok. Thanks. A little explanation on this behavior will be more helpful.
Ravindra K
03-15-2012 09:45 AM
Please rate...
