DEFAULT route advertisement via BGP - Conditional
csco10851021
I have requriment to advertise default route to BGP peer only if DEF route is present in routing table.
     R1-ISP (1.1.1.1)..............(1.1.1.2) CE1 (2.2.2.1)----------(2.2.2.2)CE2
- Default route is configured on CE - #ip route 0.0.0.0 0.0.0.0 1.1.1.1
- There is iBGP between CE1 and CE2
We want CE1 to advertise Default route to CE2 only when
 - CE1 has default route in his routing table OR
 - Has reachability to 8.8.8.8.
Will following configuration suffice on CE1-
ip sla 1
icmp-echo 1.1.1.1 source-ip 1.1.1.2
frequency 5
ip sla 2
icmp-echo 8.8.8.8 source-ip 1.1.1.2
frequency 5
track 1 ip sla 1
track 2 ip sla 2
track 3 list boolean or
object 1
object 2
ip route 0.0.0.0 0.0.0.0 1.1.1.1 tag 101 track 3
router bgp 10
neighbor CE2 remote-as 20
address-family ipv4
redistribute static route-map INTERNET-DEF-ROUTE
neighbor CE2 activate
default-information originate
exit-address-family
route-map INTERNET-DEF-ROUTE permit 10
match tag 101
Giuseppe Larosa
your configuration looks like correct to achieve the desired behaviour.
only note that if CE1 and CE2 should be iBGP CE2 should use the same AS number as declared in CE1 router bgp 10.
The key point is to avoid to configure default-originate under the neighbor.
See the following notes from command reference:
Usage Guidelines
The default-information originate command is used to configure a BGP routing process to advertise a default route (network 0.0.0.0). A redistribution statement must also be configured to complete this configuration or the default route will not be advertised.
The configuration of the default-information originate command in BGP is similar to the configuration of the network (BGP) command. The default-information originate command, however, requires explicit redistribution of the route 0.0.0.0. The network command requires only that the route 0.0.0.0 is present in the Interior Gateway Protocol (IGP) routing table. For this reason, the network command is preferred.
Note The default-information originate command should not be configured with the neighbor default-originate command on the same router. You should configure one or the other.
see on
https://www.cisco.com/c/en/us/td/docs/ios/iproute_bgp/command/reference/irg_book/irg_bgp2.html
The redistribution of the static route is needed ,an alternate configuration would be the use of network 0.0.0.0 instead of redistribution + default-information originate under route bgp process.
Hope to help
Giuseppe
the below should work as well:
track 1 ip sla 1 reachability
ip sla 1
threshold 1000
timeout 2000
frequency 2
ip sla schedule 1 life forever start-time now
event manager applet BGP_DEFAULT_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "router bgp 2"
action 4.0 cli command "no neighbor 2.2.2.2 default-originate"
action 5.0 cli command "end"
event manager applet BGP_DEFAULT_UP
event track 1 state up
action 4.0 cli command "neighbor 2.2.2.2 default-originate"
This device access is controlled by TACACS. Do i need to provision separate account to run event manager script ?
the EEM script is part of thr running configuration, it doesn't require special TACACS permission.
