09-22-2021 02:42 AM
Hi everyone I have a problem in injecting the default route, let me explain.
I have a working MPLS network, with various VRFs.
The protocol used between PE-CE is OSPF.
CE-1, in its OSPF process injects the default route through the command default-information originate.
PE-1, receives the default route, redeploys in OSPF in BGP and vice versa
PE-2, in the VRF routing table, sees the default route through BGP, redistributes BGP to OSPF and vice versa.
CE-2 does not install the ddefault route.
What's wrong ?
PE-1
RP/0/RSP0/CPU0:PE-1#sh route vrf XXXXXXX
Wed Sep 22 11:30:52.989 utc
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR, l - LISP
A - access/subscriber, a - Application route
M - mobile route, r - RPL, (!) - FRR Backup path
Gateway of last resort is 10.36.0.89 to network 0.0.0.0
O*E2 0.0.0.0/0 [110/1] via 10.36.0.89, 18w6d, TenGigE0/0/1/3PE-2
PE-2#sh ip route vrf XXXXXXX
Routing Table: XXXXXXX
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 10.86.1.1 to network 0.0.0.0
B* 0.0.0.0/0 [200/1] via 10.86.1.1, 21:10:56CE-2 CE-2#sh ip route 0.0.0.0 % Network not in table CE-2#
Solved! Go to Solution.
09-22-2021 06:19 AM
In Cisco IOS-based OSPF implementation, you cannot redistribute a default route into OSPF. All other routes can be redistributed but a default route must be injected with default-information originate. So if PE-2 does not have this command configured for the OSPF process in the correct VRF, it won't retake the default route from BGP and won't have it advertised toward CE-2.
Would this explain the behavior in your setup?
Best regards,
Peter
09-23-2021 05:26 AM - edited 09-23-2021 05:27 AM
Hi Marco,
At least as far as the default route is concerned, this is an expected behavior.
Two things are important to remember:
Did you observe any other behavior? Do you have any doubts? Please feel free to ask further!
Best regards,
Peter
09-22-2021 06:19 AM
Best regards,
Peter
09-22-2021 06:27 AM
Hi Peter and thanks for the reply
the command default-information originate was inserted into the CE-1 OSPF process.
Should I include it in the OSPF process of PE-2 to CE-2?
09-22-2021 07:02 AM
Yes, precisely. Remove it from CE-2 and configure it on PE-2 instead. This command is supposed to be placed on the router that
Clearly, it's PE-2, not CE-2 : )
Best regards,
Peter
09-23-2021 05:04 AM
This is the configuration I did:
But is this behavior normal?
If I redeploy i from a routing process in OSPF, shouldn't I see prefixes in Type-5?
Hi Marco,
Best regards,
Peter
09-23-2021 05:41 AM
Thank you so much Peter
09-23-2021 05:56 AM
Hi Marco,
Very much welcome! : )
Best regards,
Peter
