- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-23-2008 04:27 AM - edited 03-04-2019 12:27 AM
How do I config eigrp to advertise the "default route" to nei? any sample config?
rdgs
Solved! Go to Solution.
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-23-2008 07:56 AM
Hello Anita,
on R1 you need also
ip route 0.0.0.0 0.0.0.0 192.168.10.1
R1 can advertise net 192.168.10.0/24 with an externa flag to a third router in net 172.16.0.0/16 via EIGRP
R2 should be out of EIGRP domain
the context is :
R3 -------- R1 --- default network -- GW=R2
<--EIGRP---->
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-23-2008 04:48 AM
Use the network command to pass the default route to neighbor.
eg.
router eigrp 110
network 0.0.0.0
Chao
Vishwa
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-23-2008 06:31 AM
can I use below config?
R1
router eigrp 110
redistribute static
ip route 0.0.0.0 0.0.0.0 192.168.0.1
any dis-adv?
rdgs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-23-2008 06:42 AM
Hello Anita,
another way to propagate a default route in EIGRP is to use the ip default-network command
router eigrp 1
network 192.168.10.0
network 172.16.0.0
ip default-network 192.168.10.0
the requirements are:
the network in the default-network has to be in another major network (Class A,B, C)
a network command for it has to be present in the EIGRP process.
In this case the network propagated is that of the default-network with an EIGRP flag that signals the capability to be network of last resort.
It works also if the network is reached via a static route not only if it is a connected subnet.
This command is also supported by RIP but not by link state protocols
note: the router advertising the default route needs to have its own default static route to be able to route to gateway of last resort.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-23-2008 07:16 AM
Hi Giuseppe,
I config R1 with
R1
router eigrp 1
network 172.16.0.0
and
R2
interface fe0/0
ip address 192.168.10.1 255.255.255.0
router eigrp 1
network 192.168.10.0 255.255.255.0
ip route 0.0.0.0 0.0.0.0 210.12.1.1
Is it correct?
rdgs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-23-2008 07:56 AM
Hello Anita,
on R1 you need also
the context is :
<--EIGRP---->
Hope to help
Giuseppe
