Default route tracks IP SLA - Tip
Julian Ortiz
Hi community,
I need a tip for the following scenario. I have two branches with routers 1 and 2 (R1 and R2). I want R2 reaches the Internet through the upper path (MPLS A), and in case there is something wrong here, it goes through the lower path. For this, I am going to create a primary and secondary default routes on R2 with differents ADs. I am going to create a IP SLA to ping 8.8.8.8 through the upper path with a PBR, track this IP SLA, and use this track to use or not the primary default route.
The configuration on R2 will be something like this:
ip sla 1
icmp-echo 8.8.8.8 source-ip R2_int_loopback_1
ip sla schedule 1 start-time now forever
track 1 ip sla 1 state
ip route 0.0.0.0/0 IP_RC track 1
ip route 0.0.0.0/0 IP_RD 200
ip local policy route-map ping_ipsla_over_upper_path
route-map ping_ipsla_over_upper_path permit
match ip address 101
set ip next-hop IP_RC
access-list 101 permit ip host R2_int_loopback_1 host 8.8.8.8
Then, my doubt is, is this fine? Will the IP SLA pings reach 8.8.8.8 because the PBR configuration? Or will they need also the primary default route to have a route on the IP routing table?
Many thanks,
Julián
15 Replies 15
Hello
The PBR is only for iPSLA nothing more it isn't for any traffic routing, although it needs the primary default static route to reach its sla destination sourced from R2 primary ISP interface, Now if/when reachability to that destination fails via this interface the the same icmp tracking cannot be seen via its secondary backup default static route, hence the set to null interface is applied to negate such occurrence..
Kind Regards
Paul
