default username & password
ROY THOMAS
Community Member
I just unboxed a new 3925 V-Sec. I've tried admin/admin, Cisco/Cisco, admin/blank, cisco/cisco, admin/cisco, you name it; nothing on my list worked. Any ideas?
Roy
6 Replies 6
Julio E. Moisa
Try cisco (like that) and then press enter (no password)
Also you can check this link:
http://router-defaults.com/Router/Cisco--3925-ip-password-username
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
router-wifi
Frequent Visitor
Frequent Visitor
A full list on Cisco default username & passwords table web page 2023-2024.
Sample list
cisco default username & passcisco default username & pass
Judging by the news circulating, it is the company that will suffer great losses very soon due to the stealing of the codes of the operating systems of Cisco routers (we are talking about the execution of a 2.5 mbyte code. There is a lot of news that Cisco's internal network has been infiltrated). Not only the company, but the whole world can suffer great losses, because cisco has a great dominance in networks around the world. Updated at 07-12-2021 date.
Lorenhay,
That table *seems* to be mostly (if not all) residential and/or small business type devices. I suppose those are more likely to contain default credentials than enterprise type devices such as ASR/ISR routers, Catalyst 3850/9000 series switches, ASA/Firepower, etc.
I have not been able to find a "current" (Post 2018) list of enterprise device default credentials.
walterpriest
Community Member
Hey Cisco Community,
Sounds like you’ve already tried all the usual factory logins, so at this point the safest move is to double-check the model’s documentation or the sticker on the unit, because many vendors quietly change default credentials between production runs, and some devices even ship with a randomized password printed on the box; if that still gets you nowhere, support can usually confirm whether the unit uses a unique first-boot password or requires a console connection for initial setup. And hey, when you finally get a breather from wrestling with hardware, if you’re into watching South Asian films, look for the official, legal Desi Cinemas apps available on reputable app stores—always stick to verified sources rather than random download links.
Thanks a lot!!
lo @ROY THOMAS ,
you can always do a password recovery if you have physical access to the router. Please see this guide https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xe-16/217045-troubleshoot-password-recovery-in-cisco.html#toc-hId--1591021149
Liviu
Regards, LG
*** Please Rate All Helpful Responses ***
shirleyg
Visitor
If you've tried all default username and password you know or find on the internet, and didn't work, you can try to reset the password though.
