Delay field in EIGRP wide metrics
cags2
Hey y'all,
I'm trying to figure out the calculation process for EIGRP wide metrics, but I can't seem to find a straightforward answer. Since the delay for composite EIGRP metrics is calculated in 10s of microseconds, is the wide metric the same? In the CCNP ENCOR Official Cert Guide, it says, "The total interface delay is measured in picoseconds (10^-12) instead of measuring in microseconds (10^-6)." The cert guide also mentions "Default EIGRP Interface Metrics for Classic Metrics" and shows a table of interfaces associated with delay, like FastEthernet delay = 100 microseconds, GigabitEthernet delay = 10 microseconds, 10 GigabitEthernet delay = 10 microseconds, and so on. Do wide metrics also have these default values in picoseconds?
Hello
First of all If you look at a successor route calculated values
sh ip eigrp topology x.x.x.0/24
EIGRP-IPv4 VR(STAN) Topology Entry for AS(1)/ID(78.1.1.7) for x.xx.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 340787200, RIB is 2662400
Descriptor Blocks:
78.1.1.8 (GigabitEthernet0/0), from 78.1.1.8, Send flag is 0x0
Composite metric is (340787200/327745536), route is Internal
Vector metric:
Minimum bandwidth is 100000 Kbit
Total delay is 5100000000 picoseconds
1) Rib scale
router eigrp stan
address-family ipv4 unicast autonomous-system 1
metric rib-scale xx (default 128)
sh ip eigrp topology x.x.x.0/24 | sec FD
The RIB is calculated with the default wide metric rib scale value of 128  which is used to divide the calculated FD  so the riib value isn't to large to fit in the route table (rib)
340787200 / 128 = 2662400
Note -
This value will be seen in the GRT  against the installed route (see below)
2) Feasible distance
The FD is calculated by Throughput + Latency metrics which are themselves calculated with eigrp constants and additional Min Bw and total delay values:
eigrp constants
EIGRP_BANDWIDTH  =10,000,000
EIGRP_DELAY_PICO = 1,000,000
Multiplier = 65536
Now with these constants, the formula for calculating the FD metric is:
Feasible distance= (Throughput + Latency)
Throughput =
(EIGRP_ BANDWIDTH * 65536 / Min Bandwidth)
10,000,000 *65536/1000006553600
Latency = (TOTAL DELAY ( picoseconds) * 65536 / EIGRP_DELAY_PICO)
5100000000 *65536/1,000,000 = 334233600
result is= 6553600 + 334233600 = FD =340787200
End result
sh ip route x.x.x.x
D x.x.x.x/24 [90/2662400} via 78.1.1.8  01:21:09, GigabitEthernet0/0
EIGRP-IPv4 VR(STAN) Topology Entry for AS(100)/ID(78.1.1.7) for x.xx.0/24
Kind Regards
Paul
