delete of mode enable on routeur
akpeliodon
Hello panel I would like to know if there is a way for my problem I removed the enable secret mode on my router now when I access the router with my user account I cannot switch to privileged mode it tells me when I type enable it tells me error in authentication
4 Accepted Solutions
akpeliodon
i do in mode config : no enable secret 5 $1$cCuG$l37/pEi/V78sBw6IL4W2r.
Unfortunately
You need to password recovery' I thought you config any aaa auth enable but there is no' so one only solution recover password.
MHM
Are I going to find my existing configurations again or I have to start all over again?
Did you wr after remove enable password?
If not
Reboot the device and it will return to point before you remove enable password.
Goodluck
MHM
10 Replies 10
share the config
MHM
Building configuration...
Current configuration : 8151 bytes
 Last configuration change at 14:58:39 UTC Thu Aug 10 2023 by odon
version 15.4
service password-encryption
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn FGL1910223C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
transport input ssh
line vty 5 15
transport input ssh
scheduler allocate 20000 1000
end
akpeliodon
Unfortunately
MHM
If not
Goodluck
MHM
unfortunately i do it
I went with cable console on the router I then accessed and reconfigured the enable secret mode but still during the ssh connection when I do enable it always comes out the message: error in authentication
a factory default reset might be the simplest option. Here is the process:
1. Console into the Router:
Connect to the router using a console cable and a terminal emulation program such as PuTTY or Tera Term.
2. Reboot the Router:
Reboot the router by power cycling it or using the reload command.
3. Interrupt the Boot Sequence:
During the boot process, press the Ctrl + Break (or Ctrl + Pause) keys to interrupt the boot sequence and access ROMMON mode. This may require multiple attempts depending on the timing.
4. Change the Configuration Register:
Once in ROMMON mode, issue the following command to change the configuration register to ignore the startup configuration:
confreg 0x2142
5. Reset the Router:
Restart the router by issuing the reset command.
reset
6. Skip Initial Setup:
When the router reloads, it will prompt you to enter initial configuration mode. Enter no at each prompt until you reach the router's command-line interface (CLI).
7. Load the Startup Configuration:
Load the startup configuration into memory:
copy startup-config running-config
This step is necessary to ensure that you have access to the current configuration.
8. Change the Enable Password:
Enter privileged EXEC mode:
enable
9. Enter global configuration mode:
configure terminal
10. Change the enable password:
enable secret <new_password>
Replace <new_password> with the desired new enable password.
11. Change the Configuration Register Back:
Exit global configuration mode:
exit
12. Change the configuration register back to the default value:
config-register 0x2102
13. Save Changes:
Save the configuration:
write memory
This saves the changes, including the new enable password, to the startup configuration.
14. Verify Access:
Verify that you can access privileged EXEC mode with the new enable password:
enable
I then accessed romon mode I did confreg 0x2142 on my router I am at romon 50 without finding a restart, is this normal?
