this is a very generic question , the first thing I would do is check what the routes are what they are used for an then check if there still in reach and valid routes. Only you can decide if there still needed its your network .
If you decide after that you still dont want them you must first see what they are , whether static or IGP earned routes , either delete the static or remove the advertisement from the IGP process to remove the route from the routing table
