delete vtp domain xxxx
cfajardo1_2
anyone knows how to delete vtp domain? its configured on a 3750 and i just cant delete it.
thanks
10 Replies 10
cisco_lad2004
Level 5
Level 5
try to rename it or change to transparent mode then back.
it is in transparend mode
Amit Singh
When you configure a domain name, it cannot be removed; you can only reassign a switch to a different domain.
-amit singh
To go back to the factory default "null" domain on IOS switches, like the 3750, you have to delete the vlan.dat file in flash. This will also delete all non-default vlans.
Switch#delete flash:vlan.dat
Delete filename [vlan.dat]?
Delete flash:vlan.dat? [confirm]
Switch#reload
System configuration has been modified. Save? [yes/no]: no
This will not delete the non-default configuration file, just the vlans, VTP domain and reset the config rev# to 0
If you want to truly go back to factory defaults (non-configuration file & the vlan and VTP information) then do the following:
Switch#erase start
Erasing the nvram filesystem will remove all files! Continue? [confirm]
[OK]
Erase of nvram: complete
Switch#reload
Proceed with reload? [confirm]
Hope this helps
Rody
vtp domain null
markwgallagher
The default is a NULL string, just blank.
try setting the domain again with no value, and it should go back to the empty, default setting.
il try that. thx
studentbhai
vtp domain null
Deepak Kumar
As you can't delete the VTP domain name. There will be something name as NULL or anything else. The best practice is that change the VTP domain name from existing to another name.
Also, you can delete the vlan.dat file.
After changing the VTP name to any other name check the revision number must be 0.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
You do this by deleting the vlan.dat file in the flash and reloading the switch, however note if this switch is connected to another switch that is actively running a vtp database then that reloaded switch could again assume the vtp configuration so disconnect it from any other switch and when it has been reloaded change the Vtp mode to Transparent.or off. before re-attaching it to the network
Kind Regards
Paul
