deleted bootflash
Wt_swordfish
I have an router 7500 and deleted bootflash.
now, the router only enter in rommon and it has not option for copy the bootflhas for ftpt server.. how do i recover el boot ?
ankurbhasin
Level 9
Level 9
Hi Friend,
This link will help you to recover the router from rommon
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Ankur
No i have not never file of the boot.. i can only enter in the rommon
hi
you must use xmodem from the rommon mode to copy an ios image from your pc to the router through the console port.
Either use the xmodem command or use a pcmcia card in a slot0: or a similar slot that your router has.
hth
cheers
arav
