Deleting ACL list
goat1
How to delete all ACL list, for example I have access list named "Printer" and how to completely remove it.
no ip access-list standard x
8 Replies 8
first deactivate it by
interface
no ip access group NAME
then
No access-list NAME
What if I have not implemented it on any interface yet but even tho I want to delete it.
no access-list NAME
doesn't work
first do
show ip access-list
check the name as it appear there
use same name with
no access-list
If you want just share the
show ip access-list
and point which ACL you want to delete and I will send you exact command.
I've tried
 no access-list x
no ip access-list x
try with add IP
Still nothing
I may say it works
I had standard acl so I changed extended to standard
Thanks for help !
