Deny traffic to transit network
SJ K
Level 5
Level 5
Hi all
I need to prevent workstation on the right to access the 10.10.10.x network but its traffic will still need to flow through gateway
30.30.30.1 -> 10.10.10.1 -> internet
If i create an ACL on R1 to prevent the workstation from accessing the 10.10.10.x network - will R1 still route the workstation traffic to 10.10.10.1 ?
Thank you
Jon Marshall
Yes it will because the destination IP of the traffic from the PC won't be 10.10.10.1, it will be internet IPs and you are not blocking those.
Jon
Jon Marshall
Jon
balaji.bandi
what is the use case here to block transit ?
is this a big network ? so you can deny  anything  on 10.10.10.X  network and you need to allow to transit IP to work ?
or you need to build a GRE Tunnel R1 and R2, make over-engineering. (depends on the use case.)
BB
