Denying default route with route-map DENIED due to: route-map
Letau Matlou
Hi All
I have an issue where i am trying to deny only the default route coming from a BGP peer with an INBOUND route-map, however the route-map seems to be denying all routes. I have tried this with the route-map matching an access-list and again with the route-map matching a prefix-list. As per below BGP update debugs on R2 all routes are blocked
*Feb 8 14:36:57.999: BGP(0): 192.168.50.1 rcvd 0.0.0.0/0 -- DENIED due to: route-map;
*Feb 8 14:36:57.399: BGP(0): 192.168.50.1 rcvd 192.168.50.1/24 -- DENIED due to: route-map
Please assist
Below is the configs
 R1----------R2
######R1##########
int loopback 1
ip address 192.168.50.1 255.255.255.0
interface fa 0/0
description "CONNECTED TO R2"
no shut
router bgp 64512
neighbor 192.168.1.2 remote-as 64513
network 192.168.50.0 mask 255.255.255.0
network 0.0.0.0
ip route 0.0.0.0 0.0.0.0 null 0
#######R2
interface fa 0/0
description "CONNECTED TO R1"
ip address 192.168.1.2 255.255.255.0
no shut
router bgp 64513
neighbor 192.168.1.1 remote-as 64512
neighbor 192.168.1.1 route-map BPG-NEIGHBOR in
ip access-list extended DEFAULT-ROUTE
permit ip 0.0.0.0 0.0.0.0 any
route-map BPG-NEIGHBOR deny 10
match ip address  DEFAULT-ROUTE
route-map BPG-NEIGHBOR permit 20
Hello
At the moment you denying all routes, if you change the access-list to aa prefix-list you should be able to deny the default route much easily.
Example:
ip prefix-list DEFAULT-ROUTE deny 0.0.0.0/0
ip prefix-list DEFAULT-ROUTE permit 0.0.0.0/0 le 32
route-map BPG-NEIGHBOR permit 10
no match ip address DEFAULT-ROUTE
match ip address prefix-list DEFAULT-ROUTE
no route-map BPG-NEIGHBOR permit 20
clear ip bgp * soft
Kind Regards
Paul
Hello
Example:
clear ip bgp * soft
Kind Regards
Paul
Hi Paul
Thank you for the quick response, it worked after adjusting my configs
Another thing i realized is that when i was trying to use a prefix list, instead of matching as "match ip address PREFIX-LIST" i would just match as "match ip ADDRESS" and it would deny everything as it tried to reference an ACL and not PREFIX-LIST
Thanks a mill,,,, now i know that:::: "match ip address" is for ACL and "match ip address prefix-list" is for PREFIX-LIST
