design for two routers with NAT and 4 ISP connection
homephoneone
Here is my setup
two Cisco 3825 with 4 ethernet connection.
4 ISP connection
Router 1  -  ISP1 and ISP 2
Router 2  -  ISP3 and ISP 4
I will be using NAT and HRSP on both routers.
I'm having problem with NAT and I was wondering if anybody know
which NAT or PAT design I should be using?
For each internet-connection you need one route-map that matches the traffic that should be natted and the outgoing interface. Here is an example for dynamic outgoing PAT:
ip nat inside source route-map NAT interface GigabitEthernet0/0 overload
ip nat inside source route-map NAT-VDSL interface Dialer0 overload
route-map NAT permit 10
  match ip address NAT
  match interface GigabitEthernet0/0
route-map NAT-VDSL permit 10
  match ip address NAT-VDSL
  match interface Dialer0
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Bharat Negi
Please go through this thread.
https://supportforums.cisco.com/message/767009
Bharat
Should i be using a loopback address?
what about IP route? and default route?
