Design question
pronin_sergey
Hello guys,
our company has the following design.
  • Three datacenters in different countries.
  • In each DC there is a core. It is usually stacked 3750X switches.
  • OSPF runs on the cores to exchange internal routes
  • Two borders in each DC. It might be Cisco, Juniper or even Linux. Borders run multimode BGP with various providers.
  • Each DC announces its own /24 network.
  • There is a full mesh iBGP between borders on virtual interfaces, that are built over internal OSPF.
Question is:
Is it a good design or not?
1) I would like to move iBGP to cores and configure route reflectors on them. Is it a good idea?
2) We have a public prefix /21. Instead of announcing /24 in each DC I would like to announce /21 in all DCs + /24 in each. But I don't know what to do with the firewalls in each DC. They are stateful.
Sergey
Hello.
If run full-table BGP, I would say it might be a bad idea to run BGP inside your network.
If you learn only 0.0.0.0/0 via BGP, then it's easier to redistribute it into IGP per DC.
Regarding public prefixes - /21 vs specific /24s might be a good idea; if you have DMZ, then the challenge is to route traffic to proper DMZ (you may try it with different VRF).
PS: it's hard to say if it's good design or not, we need to know what are the original business requirements and where different services will be located.
