Destination Host Unreachable
yuyuuuu
Hi i need some help. i can ping BLUE and PINK together but i can't ping PINK to YELLOW or BLUE to YELLOW. seems like there's a problem with my router connection? but i'm unable to find the problem. help are very much appreciated
@yuyuuuu
Modify IP on serial 2/0 on Left Router:
-- configure 10.0.0.1 255.0.0.0
After that you will see RIP routes on routers. Do
#show ip route !
Best regards
9 Replies 9
M02@rt37
Helo @yuyuuuu,
Please do #
show ip route
on Routers. Check serial configuration on Routers also.
Share ouput here.
Thanks.
Best regards
i posted as a reply
@yuyuuuu
please share you packet project here
Best regards
@yuyuuuu
#show ip route !
Best regards
oh my it works. thanks a lot for helping!
yuyuuuu
urmm does this help?
Blue_Bird
Hello Yuyuuuu,
It seems all connections are fine...May be problem is  with routing.....Have you configured any static routing or  other protocol....?
as M02@rt37 mentioned, Please share the device configurations...It will be helpful...
Please provide the output of show ip route  from both routers....or show running-config of both routers is fine..
Best regards
******* If This Helps, Please Rate *******
i used RIP routing instead of static is that okay?
