Destination NAT based on source subnet
rkatarzy
I am in a situation where the provider is advertising 2 subnets via the Mobistar router. I cannot do any changes on this Mobistar router.
-C4 is in Subnet 10.10.10.0/24
-C3 is in Subnet 10.10.11.0/24
RouterANT is a router on a stick towards SW3, and handles the traffic from C4 & C3 to the Mobilink_server(10.0.0.1/24).
This is the situation I want to have:
-C3 (10.10.11.1) needs to connect to VDCMobilink(192.168.0.1) instead of Mobilink_server(10.0.0.1/24). I need to NAT the destination traffic for 10.0.0.1 to 192.168.0.1
-But the traffic from C4 towards the Mobilink_server can not be translated and must remain unharmed.
-The only place I can change configuration is RouterANT
Is this possible? And how can I accomplish this?
8 Replies 8
Jon Marshall
Firstly i do not have a router to test this on so you try it at your own risk ie. if it stops communication within your network don't hold me responsible.
The interface on RouterANT that the traffic from 10.10.11.1 arrives on should have "ip nat outside" configured on it. The interface connecting to the VDCMobilink server should be "ip nat inside". The rest of the config -
ip nat inside source static 192.168.0.1 10.0.0.1 route-map NAT extendable
access-list 101 permit ip host 192.168.0.1 10.10.11.1
route-map NAT permit 10
match ip address 101
What this should do is only translate 192.168.0.1 to 10.0.0.1 when communicating with 10.10.11.1
As i say, no guarantees because i can't test it so i would do it out of hours if you can.
Jon
Hi Jon,
Thanks for the reply. I justed tested this in GNS, but the destination traffic orginating from 10.10.10.0/24 is also translated to the destination ip 192.168.0.1.
Raf
Raf
What do you mean. Can you give me an example ?
Jon
Jon,
I mean that the traffic originating from 10.10.10.1/24 an 10.10.11.1/24 has a destination translation 10.0.0.1 ->192.168.0.1
traffic from 10.10.10.1/24 should go to 10.0.0.1 directly.
A extra comment: traffic from 10.10.10.1 and 10.10.11.1 arrives on the same interface on RouterANT. that interface has "ip nat outside" configured on it.
Raf
Raf
Sorry, there was a typo in my acl. Instead of -
it should be -
access-list 101 pernit ip host 192.168.0.1 host 10.10.11.1
Jon
Hi Jon,
A typo is not possible in a router ;), I added the entire subnet.
access-list 101 permit ip host 192.168.0.1 10.10.11.0 0.0.0.255
Raf
Raf
Then i can't see why it would tranlsate the 10.10.10.0/24 network as well because that is not allowed in the acl.
Jon
Hi Jon,
Even with a deny any any on access-list 101, the translation goes through. Very strange.
Raf K
