Destination NAT or Hide NAT
NeWGuy1109
I have a doubt while doing Destination NAT or Hide NAT for Multiple IPS.
Suppose - 192.168.1.1-10 --> 10.10.10.11 & 10.10.10.12 on port 80
I want 192.168.1.1-10 to hit 2.2.2.2 and that will get translated to 10.10.10.11 & 10.10.10.12
My Question is can i use a single NAT ip for both these destinations ? Suppose one of the IPs makes a connection to 10.10.10.11 with NAT IP 2.2.2.2 , will another connection be successful with only one NAT IP and same port ?
5 Replies 5
it is unclear what you are trying to accomplish:
You want 192.168.1.1 thru 192.168.1.10 translated to 2.2.2.2 first, and then to either 10.10.10.11, or 10.10.10.12 ? All IP addresses are configured on the same router ?
Hello
Sounds like you may need to LB your nat but to clarify
192.168.1.1 -10 are you inside local addresses (lan)
10.10.10.11-12 are you inside global addresses (wan)
2.2.2.2 is a public ip address that you want to reach and is reachable from 10.10.10.11-12
Example of possible NAT LAB
access-list 100 permit tcp host 10.10.10.11 any eq 80
access-list 100 permit tcp host 10.10.10.12 any eq 80
ip nat pool LB 192.168.1,1 192.168.1.10 prefix-length 24 type rotary
ip nat inside destination list 100 pool LB
Kind Regards
Paul
Its a multi Tenant Environment where the Source Address are a group of 192.168.1.1-10 (10 IPs) and they need to reach the Destination 10.10.10.11 and 12.
But there is a restriction for traffic flow with respect to these subnets , so i want to DNAT/HideNAT the Destinations behind the routable 2.2.2.2. But the Problem is that i feel DNAT is one to one only and if i assign a single NAT IP to 2 Destinations it might not work for both of them
Hello
So the 10.10.10.11-12 are outside your lan network and visibility into your network is for these hosts is to hit 2.2.2.2 correct
hosts  >10.10.10.11-12 <--> 2.2.2.2 <nat lan>192.168.1.1 -10
So if the above is correct and the example i provided previously traffic from those two host should load balance to your lan host in the nat pool
Kind Regards
Paul
Thanks for the reply...
For a better understanding suppose there is a following Static NAT rule .
Source - 192.168.1.1 Destination 10.10.10.1-10    Translated Source - Same      Translated Destination 10.80.25.1-10
So in this case each IP for Destination 10.10.10.X will be translated to 10.80.25.X for each individual communication ?
