Determine the type of Network Module installed on 3660
ymitikou-328
I'm trying to determine what type of network module is installed on a 3660 router in slot 3. When I use the show diag command, I only see the daughter cards on the module and not the part number for the network module itself. Can anyone help? Here is the output of sh diag on slot 3:
Slot 3:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision: 1.1
Top Assy. Part Number: 800-03567-01
Board Revision : F1
Deviation Number : 0-0
Fab Version: 02
PCB Serial Number: JAB04520CPL
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History: 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 46 31 80 00 00 00 00 02 02 C1 8B 4A 41 42 30
0x20: 34 35 32 30 43 50 4C 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
T1 (1 Port) Multi-Flex Trunk WAN Daughter Card
Hardware revision 1.0 Board revision B0
Serial number 21478231Part number800 03568-02
Test history0x0 RMA number 00-00-00
Connector typePCI
EEPROM format version 1
0x20: 01 20 01 00 01 47 BB 57 50 0D F0 02 00 00 00 00
0x30: 58 00 00 00 01 01 03 00 FF FF FF FF FF FF FF FF
HDV firmware: Compiled Thu 27-Dec-01 13:28 by miriyala
HDV memory size 524280 heap free 202681
amit-singh
Level 8
Level 8
Please paste the " show version" from your router.
HTH,
-amit singh
Here is the sh ver
IOS (tm) 3600 Software (C3660-IS-M), Version 12.2(19), RELEASE SOFTWARE (fc3
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 12-Aug-03 22:08 by kellmill
Image text-base: 0x60008940, data-base: 0x611A0000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
uptime is 9 weeks, 1 day, 9 hours, 42 minutes
System restarted at 04:01:48 EDT Tue Oct 3 2006
System image file is "flash:c3660-is-mz.122-19.bin"
cisco 3660 (R527x) processor (revision 1.0) with 88064K/10240K bytes of memo
Processor board ID JMX0633L8BU
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
2 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
4 Channelized T1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Checking the show version I think we have VWIC-1MFT-T1 card for you.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080091b9c.html
Let us know if " show inventory" command runs on your router. If yes, then check if it gives some information for the above listed module.
Please check for more 3600 router modules info on the link below:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_relevant_interfaces_and_modules.html
HTH,
-amit singh
thanks for the information. The show inventory command doesn't work on my router. Is there any other command that can show the modules on this router?
