09-18-2017 07:29 AM - edited 03-05-2019 09:08 AM
I'm struggling with the Feature Navigator to find a suitable Cisco device, so I hope to get some help here.
Layer 2: In our installation a number of VLANs will arrive on a SFP trunked port. The RJ45 ports are assigned to different VLANs.
Layer 3: In each VLAN there must be a BGP client since each virtual LAN has completely independent and possibly overlapping subnets, routing etc. So, we probably need VRF and the "Per-VRF Assignment of BGP Router ID" feature. An additional VPN per VRF would be great.
So, the feature list of the device is:
For me, it's a bit tricky to map the platforms in the feature navigator to actual devices. The additional challenge is to find the cheapest device supporting these features.
Any advice how to proceed with device selection? Can anyone help with the specific request above?
Thanks.
09-18-2017 07:43 AM - edited 09-18-2017 07:43 AM
Below you will find useful links:
https://www.cisco.com/c/dam/assets/prod/switches/cisco-switch-selector-how-to/index.html
https://www.cisco.com/c/dam/assets/prod/routers/cisco-router-selector/index.html
Once you have selected a device, verify the license type in order to see if that is aligned to your requeriments. Also you can compare the models of a platform serie.
Hope it is useful
09-19-2017 05:24 AM
I've tried the switch/router selector before but I had the impression that they do not cover all devices, i.e. that some devices will never be in the result set no matter what you select. Therefore, I don't trust these selectors...
09-18-2017 07:46 AM
09-19-2017 05:33 AM
Thanks for the suggestion. It seems this fits well.
What about a 3650? I don't need StackPower.
What about a 9300? I've read that it's the successor of the 3850 and (currently?) it's cheaper than the 3850, even with the Networked Advantage pack. However, I'm not really sure how to integrate 3 fiber uplinks there since the C9300-NM-4G module seems to support copper only?
09-19-2017 05:38 AM - edited 09-19-2017 05:41 AM
Cisco 3650 is similar to 3850 but I think it is pointing for access switches. Please check this link:
https://www.cisco.com/c/en/us/products/switches/catalyst-3650-series-switches/models-comparison.html
Abount the C9300, this a recent switch model, it supports Fiber modules like 3650 and 3850, now if you are looking for a switch with more SFP ports you could use a C9500. They support multi gigaethernet ports.
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-09-cat-9k-aag-cte-en.pdf (there are links for each model)
https://www.cisco.com/c/en/us/products/switches/catalyst-9300-series-switches/index.html
