DHCP for Inter-VLANs
farrukh19911
On PT it is working well, but on real network it isn'n working.
On real Network as a dhcp-relay, i have an 3750G Sw (Version 12.2(44) SE5, RELEASE SOFTWARE (fc1)
Ip routing is on.
All made as in the scheme, but i dont know why it didn't works.
Somebody can help me to solve this problem?
Does the DHCP server work?
is there a scope for vlan 59? if not can you make one and test a client on vlan 59
or you could put the dhcp server on the switch
5 Replies 5
do you have the ip helper commands on the interface vlan 60 and 70
int vlan 60
ip helper-address 192.168.100.3
Yes, ip helper-address 192.168.100.3 is also existing on vlans 60 and 70..
Packets reach the DHCP servers from the gateway VLAN 60 (20.1) with MAC address of VLAN 59, but do not go in a reply.
I put the log file.
When I appropriate a static IP for the host, it is working.
Even appears on the MikroTik dhcp server the host address and his name
I tested a client on vlan 59, it is working well.
Thanks a lot for everyone. I solved my problem and a biggest thank to my friend Konrad Zolsky.... http://geks0gen.blogspot.com/
