DHCP on Cisco Device
prabhu050446
Hello Everyone,
We migrated DHCP service from Windows to Cisco Device (works perfectly fine) but our PXE imaging is broken after migration.
I was trying trial and error and found below based on our requirements.
Requirements: All devices (Microsoft Surface and HP Z840 desktops) should be able to PXE imaged.
Set Up: our imaging server (SCCM server) is on VLAN 100 and imaging clients (HP Z840 and Surfaces) are on VLAN 200. Already have IP helper on the client VLAN.
Observations:
a) If I have only dhcp option 60 PXEClient configured under cisco DHCP scope then Surface PXE imaging works but not HP Z840.
b) If I have only Option 67 with filename smsboot\x64\wdsnbp.com then Z840 work but not Surface.
No other options like 66 or combination of 60, 66 and 67 works.
Cant go back to Windows because of valid internal reasons.'
The only difference I see between Windows DHCP service and Cisco DHCP serviced packets is that during the Windows DHCP offer I see Option 60 being sent by Router to Client, same is not done during Cisco DHCP Offer
Below are the scenarios that worked separately for device type, but I am looking for configuration that works for both/all of the device types.
Device
IP Helper
VLAN
Option 60
Option 66
Option 67
Opt 67 filename
success
Microsoft Surface
yes
2004
yes with PXEClient
no
no
no
YES
HP Z840
yes
2004
no
no
yes
YES
Thank you in advance.
6 Replies 6
Deepak Kumar
Try your DHCP pool configuration like this:
ip dhcp pool DATA_LAN
network 10.250.1.0 255.255.255.0
default-router 10.250.1.1
option 66 ip 10.250.1.2
option 67 ascii smsboot\x64\wdsnbp.com
dns-server 10.111.18.241 10.111.18.242
domain-name xx.local
Also noticed this bug (If option 67 is getting change): https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsi10974/?rfs=iqvred
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thank you Deepak for the reply.
I dont think I am impacted with that bug.
Thank you
Dharmendra
I am not saying the switch is infected with this bug. But it is shared for your information only.
Deepak Kumar
Deepak Kumar,
Hello
ip dhcp pool xxx
option 66 ip x.x.x.x
option 67 ascli "file path"
Kind Regards
Paul
Thanks a lot for the reply Paul. I tried all the combinations with Options 60, 66 and 67. If I h ave two options configured (like you suggested) then X840 works but not Surface.Below are the combinations that I already tried.
DeviceIP HelperVLANOption 60Option 66Option 67Opt 67 filenamesuccess
Z840yes200yesyesnoNANO
Z840yes200noyesnoNANO
Z840yes200noyesyessmsboot\x64\wdsmgfw.efi smsboot\x64\wdsnbp.com smsboot\x86\wdsmgfw.efi smsboot\x86\wdsnbp.comNO
Z840yes200nononoNANO
Z840yes200nonoyessmsboot\x64\wdsmgfw.efi smsboot\x64\wdsnbp.com smsboot\x86\wdsmgfw.efi smsboot\x86\wdsnbp.comNO
Z840yes200nonoyessmsboot\x64\pxeboot.comNO
Surfaceyes200nonoyessmsboot\x64\pxeboot.comNO
Surfaceyes200nonoyessmsboot\x64\wdsmgfw.efi smsboot\x64\wdsnbp.com smsboot\x86\wdsmgfw.efi smsboot\x86\wdsnbp.comNO
Surfaceyes200yes with PXEClientnononoYES
Z840yes200no no noNANO
Surfaceyes200no no noNANO
Z840yes200no no yessmsboot\x64\wdsnbp.comYES
as said earlier, the only difference I see between Windows DHCP service and Cisco DHCP serviced packets is that during the Windows DHCP offer I see Option 60 being sent by Router to Client, same is not done during Cisco DHCP Offer.
Thanks a lot.
some of the scenarios that I tried (your suggestion using opt 66 and 67) are not listed in the table as they did not work.
