DHCP on Router 2811
Amin Shaikh
One of department has a small operation with 35users.
Their requirement is
File Sharing
Internet Browsing
Emails ( Local + Internet )
Intranet
They will have Windows 2003 Domain Controller. One DATA Server for File-Sharing. One Email Server. One Intranet Server ( Share-point-portal )
In terms of Hardware will have Cisco 2960 48-port 10/100 Switch.
2811 Router with 2FE for Internet connection.
Design woud be
Internet-----ISP---Router2811---2960switch---users
I would like to get advice if its appropriate to have DHCP on a router.
If possible a cisco-link with sample configuration similiar to my scenario..
mohammedmahmoud
Level 11
Level 11
Its completely appropriate to use Cisco IOS DHCP Server on your 2811 in your case, please refer to the following document:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008743b.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Thanks Mohammed.
If you are aware of any other cisco link for DHCP sample configuration please do let me know.
You are very welcomed, you can found many documents if you searched on the cisco website, but i guess that the document i've provided contains almost all that you need, and also here is another one:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75c.html
HTH,
Mohammed Mahmoud.
