DHCP Option-82
nwekechampion
Level 3
Level 3
Hi All,
Can anyone explain what dhcp option-82 is used for?
Like any specific use-cases?
I really do not see the point in using it as I have always had success relaying with out it to dhcp server.
22 Replies 22
first the op-82 is add from SW or from router (relay)
for SW I explain before the use of class <<- this if need lab I can run
for Router relay I already finish lab for this case I will share here after 1-2 hrs.
in MPLS SP core you can use DHCP relay with op-82 to provide IP to CE depend on VRF that CE connect to.
ah, this makes sense now.. depending on VRF.
However in your config I did not see an option-82 entry
Hi @MHM Cisco World ..
I am yet to lab this and test it myself.
As soon as I do, I will update you.
Thank you again!
So Sorry, I see your previous comment, I will share the traffic capture to see OP-82 in real traffic.
thanks
MHM
config of lab
hostname R5-P-DHCP
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
ip dhcp pool VRF-RED
vrf RED
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip dhcp pool BLUE
vrf BLUE
network 11.0.0.0 255.255.255.0
default-router 11.0.0.1
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
shutdown
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
ip address 100.0.0.5 255.255.255.0
mpls ip
serial restart-delay 0
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
ip address 200.0.0.5 255.255.255.0
mpls ip
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
router ospf 100
network 100.0.0.0 0.0.0.255 area 0
network 200.0.0.0 0.0.0.255 area 0
R2-PE2#show running-config
Building configuration...
Current configuration : 1678 bytes
version 15.2
hostname R2-PE2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip vrf BLUE
rd 1:100
ip dhcp relay information option vpn
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip vrf forwarding BLUE
ip address 11.0.0.1 255.255.255.0
ip helper-address global 200.0.0.5
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
ip address 200.0.0.2 255.255.255.0
mpls ip
no ip address
shutdown
negotiation auto
router ospf 100
network 2.2.2.2 0.0.0.0 area 0
R4-CE2#show running-config
Current configuration : 1375 bytes
version 15.2
hostname R4-CE2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address dhcp
duplex full
Thanks @MHM Cisco World .. this was really helpful
